Newb Question re 2d drawings..
- thomas-neemann
Re: Newb Question re 2d drawings..
This is what it should be, the smaller holes are just counterbores..
I have attached the FreeCAD file I created with the dxf file you posted.
I did a couple settings in the Preferences for DXF import. I set it to use legacy importer and ticked the Join geometry checkbox.
I then imported the file. It contained a bunch of geometry. I selected the geometry for the outer block and converted to sketch, then did the same for the large circles, and again for the small circles. This was because I intended to use the hole tool to create the counterbores. (that ended up not happeneing, because the holes a b-splines and the hole tool gets it's location from the center of a circle...)
- Plate-mac.FCStd
- (374.07 KiB) Downloaded 10 times
