OS: Debian GNU/Linux 10 (buster) (XFCE/xfce)
Version: 0.19.23578 (Git) AppImage
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Workbench A2plus V0.4.48
Open FreeCAD, Create New, switch to A2Plus workbench, save as "assembly.FCStd".
Add hole.FXStd first, then pin.FCStd.
Select edge on hole, STRG + select edge on pin (see screenshot)
Click "Add an axisCoincidence constraint"
An error is shown in the console:
Running the Python command 'a2p_AxialConstraintCommand' failed:
File "/home/andy/.FreeCAD/Mod/A2plus/a2p_constraintcommands.py", line 167, in Activated
c = a2p_constraints.AxialConstraint(selection)
File "/home/andy/.FreeCAD/Mod/A2plus/a2p_constraints.py", line 386, in __init__
self.create(selection)
File "/home/andy/.FreeCAD/Mod/A2plus/a2p_constraints.py", line 104, in create
self.calcInitialValues() #override in subclass !
File "/home/andy/.FreeCAD/Mod/A2plus/a2p_constraints.py", line 391, in calcInitialValues
axis2 = getAxis(self.ob2, c.SubElement2)
File "/home/andy/.FreeCAD/Mod/A2plus/a2plib.py", line 988, in getAxis
axis = a.Axis
name 'a' is not defined
The pin is originally part of bigger STEP created by "PDElib Version 3.2.7"
and I'm unsure if I'm allowed to upload the whole STEP file due to copyright restrictions.
It looks for me like the code at a2plib.py:988 is trying to find the axis for an edge made out of multiple arcs but failed.
This also happens if the pin is converted to a "A2plus part" and also if I do not select the edge but the face on both sides.
-- Andy
[Bug, Solved] A2plus error aligning pin to hole
- assembly.FCStd
- (6.7 KiB) Downloaded 9 times
- hole.FCStd
- (10.41 KiB) Downloaded 8 times
- pin.FCStd
- (4.63 KiB) Downloaded 10 times
Re: A2plus error aligning pin to hole
i could reproduce this error and fixed it. Please update to A2plus version V0.4.49
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Thank you for your fast response.
It works perfektly in V0.4.49
Thanks you, Andy
Thanks you, Andy
