To embed in Other Application
I do not find the lib folder in stable release for FreeCAD.dll.
Please let me know if I am missing something here.
Re: To embed in Other Application
Do you want to integrate FreeCAD over its C++ interface or via Python? For the latter one you can use FreeCAD.pyd and/or FreeCADGui.pyd or any of the modules' .pyd files.
However, if want to go for C++ then you have to build FreeCAD on your own to have all the .lib files because they're not deployed with the MSI installer.
Thanks for quick reply!
I wanted to go for Python.....
Please let me know which of these path should work :
1). FREECADPATH = 'C:/Program Files (x86)/FreeCAD0.11/bin/'
or
2). FREECADPATH = 'C:/Program Files (x86)/FreeCAD0.11/bin/FreeCADGui.pyd'
sys.path.append(FREECADPATH)
import FreeCADGui
Thanks,
Manoj
or
import FreeCADGui
Thanks,
Manoj
import sys,os,platform
if platform.architecture()[0] == '32bit':
# for 32-bit version
sys.path.append(os.environ["PROGRAMFILES"]+"/FreeCAD0.11/bin")
elif platform.architecture()[0] == '64bit':
# for 64-bit version
sys.path.append(os.environ["ProgramW6432"]+"/FreeCAD0.11/bin")
else:
raise Exception("Unsupported platform %s" % (platform.architecture()[0]))
import FreeCADGui
Thanks !!
However when I added last line to this code and tried:
I do not see anything coming up, just the messages:
and program terminates.
And I am not sure what to expect coming up on the screen.
Please let me know if I am moving in right direction .
else:
import FreeCADGui
FreeCADGui.showMainWindow()
FreeCAD 0.11, Libs 0.11r4206
Main Window Restored
Show Main Window
Toolbars Restored
This works for me
The last line is needed to run the event loop which is needed for all applications using FreeCADGui that isn't based on the GTK, wxWidgets, Win32 or MFC toolkit. If the target application is based on one of these toolkits Qt is able to create a hook to the host application and gets its events from there.
Note:
When running exec_loop() the host application might be blocked. In case this happens to you and you don't want try running the exec_loop() function from a thread.
import FreeCADGui
FreeCADGui.exec_loop()
Note:
Thanks again!!!!
It worked!! of-course it had too
As I read through the tutorials, it is possible to embed the components into the wxWidgets(Python)...what I actually meant suppose I just want to pull the 3D parts only and hide all other components, even the File menu and the workbenches? Basically all the operations in background and show the Geometry only...much like an animation video...with custom controls realtime!
Thanks,
Manoj
Thanks,
Manoj
The best in this case is to make your own custom workbench in python. I this workbench you can remove all
menus and toolbars. This way you can have a complete empty FreeCAD.
Stop whining - start coding!
Thanks for the Idea...I do not know to add new workbench either
.....actually I intend to add it to the wxWidgets..it is more like testing the flexibility of FreeCAD.
Thanks,
Manoj
Thanks,
Manoj
Create a new module directory under Mod and add a file InitGui.py with this content:
class BlankWorkbench (Workbench):
MenuText = "Blank"
ToolTip = "Blank workbench"
def getMainWindow(self):
from PyQt4 import QtGui
toplevel = QtGui.qApp.topLevelWidgets()
for i in toplevel:
if i.metaObject().className() == "Gui::MainWindow":
return i
raise Exception("No main window found")
def Initialize(self):
# Just a small test
import FreeCAD
FreeCAD.newDocument()
return
def GetClassName(self):
return "Gui::NonekWorkbench"
def Activated(self):
mw = self.getMainWindow()
dw = mw.findChildren(QtGui.QDockWidget)
for i in dw:
i.toggleViewAction().setVisible(False)
mb = mw.findChildren(QtGui.QMenuBar)
for i in mb:
i.setVisible(False)
mw.statusBar().setVisible(False)
def Deactivated(self):
for i in mb:
i.setVisible(True)
mw.statusBar().setVisible(True)
Gui.addWorkbench(BlankWorkbench)
