Dark and Light FreeCAD stylesheets (2.x, 3.x,...) and beyond
Moderator: agryson
sgrogan
Re: Dark and Light FreeCAD stylesheets (2.x, 3.x,...) and beyond
Post by sgrogan » Tue Apr 19, 2016 1:39 pm
pablogil wrote: I have just checked that Windows x64 installer puts all stylesheet images inside /Stylesheets/ folder instead of /Stylesheets/images/ which make the style not to show the images...
This time it appears to be in the FreeCAD source Code
https://github.com/FreeCAD/FreeCAD/blob ... ts.txt#L23
I think it should be the same on all installed versions except the Win x86 installer (I packaged this from the build directory, not the install target). Can someone using the Ubuntu PPA (stable or daily) verify.
I'm not sure if the OS X release is packaged from the build directory or the Install Target, so the problem may exist there as well.
If verified I can submit a patch this evening.
pablogil
Post by pablogil » Tue Apr 19, 2016 3:48 pm
Oh, you are right... then it was a luck to find it because my computer is full of development /images/ folders, and any FreeCAD could read the files from there... it's curious that only x64 version don't...
Later I can check it out on my computer (windows, Mac and Ubuntu), I'll let you know
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
pablogil
Post by pablogil » Tue Apr 19, 2016 3:55 pm
derei wrote:Thank you for the clear instructions. I will apply them in my template.
There is no glitch, is just the top menu bar that has the same color like the background. I like it this way, is more uniform.
My system is Win7x64 and I use FreeCAD 0.16 rev.6698
Full screenshot attached - you can see the top menu bar goint all the way
It seems to be something inside the FreeCAD code, I can't figure out which element it is with a stylesheet... could anyone experienced on FreeCAD code have a look at it? I guess it is hard coded...
Site Admin
Post by wmayer » Thu Apr 21, 2016 12:28 pm
What about this tiny white line?
It's a QLabel that has been added to the status bar. https://github.com/FreeCAD/FreeCAD/blob ... w.cpp#L282
pablogil
Post by pablogil » Thu Apr 21, 2016 12:49 pm
If I add the following code to the stylesheet:
QLabel {
	background-color: red;
	border: 1px solid yellow;
It doesn't work:
Any other idea?
Site Admin
Post by wmayer » Thu Apr 21, 2016 12:53 pm
It doesn't work:
What doesn't work?
pablogil
Post by pablogil » Thu Apr 21, 2016 1:21 pm
wmayer wrote:
It doesn't work:
What doesn't work?
Trying to style this "white line" with the following code doesn't work:
QLabel {
Site Admin
Post by wmayer » Thu Apr 21, 2016 1:46 pm
The line must be something that adds the QStatusBar class. But it's not a widget.
pablogil
Post by pablogil » Thu Apr 21, 2016 2:39 pm
wmayer wrote:The line must be something that adds the QStatusBar class. But it's not a widget.
... so it's not stylable, doesn't it?
Could it be changed or removed to "fix" this "styling incoherence"?
triplus
Post by triplus » Tue Apr 26, 2016 8:27 pm
One idea i had for a while. What you could try out is to take dark/light stylesheet as a base and add small amount of FreeCAD branding colors to it:
http://www.freecadweb.org/wiki/index.ph ... olor_chart
I am not sure how it would turn out. But as you did Blender one maybe you will be interested in trying this out in the future.
Who is online
Users browsing this forum: No registered users and 2 guests
