Sketch icon deconfusion : // vs =
Moderator: agryson
Re: Sketch icon deconfusion : // vs =
Post by chrisb » Mon Sep 30, 2019 10:01 pm
I prefer the current equal sign as is. The proposal suggests to me much more than the equal sign that it applies to horizontal lines. And it would be especially inappropriate for arcs.
vocx
Post by vocx » Mon Sep 30, 2019 10:01 pm
DeepSOIC wrote:
Mon Sep 30, 2019 9:58 pm
It also works on:
Yes, and radiuses are lengths. If in the future it is able to handle more types of equality, then I think using the equals symbol is fine. But then, not now.
Post by chrisb » Mon Sep 30, 2019 10:12 pm
It remains confusing on equal arcs, because you don't select the radius, you select the arcs.
usbhub
Post by usbhub » Wed Oct 02, 2019 4:00 pm
I like the third version from vocx. Yes, the equality isn't only for length, but it gives the user a second difference to the parallel icon and my first association of vocx icon goes more in an equality direction than the old icon.
usbhub
Post by usbhub » Wed Oct 02, 2019 4:05 pm
Or maybe somebody can create a survey for the different icon versions.
carlopav
Post by carlopav » Fri Oct 04, 2019 9:48 pm
+1 for the third version of vox
triplus
Post by triplus » Sat Oct 05, 2019 9:06 am
Would such change do? That is by using the most universal signs out there, for equal and parallel?
freman
Post by freman » Thu Dec 12, 2019 2:20 pm
Then it is the way the tool itself works which is confusing since you select the arc lines but when you press the equality icon you do not get arcs of the same arc length or same angle but the same radius. It may be argued that an icon showing a straight line equality better represents what the tool will actually do on an arc or circle.
Selecting two angles does nothing ( "Select two or more compatible edges" ) so no issues there.
It seems that all things that the equality constraint does are consistent with the idea of a linear equality. Expressing this is more accurate than plain "equals" since in it may imply or suggest equalities in factors which it does not affect.
I like vcox' third icon best, visually. Graphically very balanced and pleasing. However, it is derived from the icon meaning equal horizontal distance and this is more specific than what equality constraint does. This is why I based my suggested icon on the existing icon for setting length, or arbitrary orientation.
Constraint_Length.svg
(13.79 KiB) Downloaded 3 times
freman
Post by freman » Thu Dec 12, 2019 4:13 pm
I've uploaded my deconfusion parallel constraint svg icon and its petit frere xpm. I think I've created a PR but I'm not sure can someone confirm?
https://github.com/J-Dunn/FreeCAD
Thanks.
openBrain
Post by openBrain » Thu Dec 12, 2019 4:16 pm
There is no PR from you to FreeCAD/FreeCAD : https://github.com/FreeCAD/FreeCAD/pull ... %3AJ-Dunn+
Who is online
Users browsing this forum: No registered users and 2 guests
