Help for a new icon design (in TechDraw WB)
Moderator: agryson
lidiriel
Post by lidiriel » Fri Dec 27, 2019 3:55 pm
is anybody can help me for create a new icon ?
It is for a new feature : a datum reference.
I am not graphic designer and i search someone for help me.
In attachment please find a first version of icon.
Bye.
TechDraw_Reference.svg
a first version.
(13.98 KiB) Downloaded 22 times
Reason: Updated thread title with contextual info
Re: Help for a new icon design
Post by chrisb » Fri Dec 27, 2019 5:29 pm
Can you explain what it is supposed to trigger?
lidiriel
Post by lidiriel » Fri Dec 27, 2019 6:19 pm
The icon is for for add the feature : "datum reference" in Geometric Dimensioning & Tolerancing.
You can see an exemple in the page : http://www.cqeacademy.com/cqe-body-of-k ... wings-gdt/
In the wikipedia example the reference is labelled A and B.
Now i create the code of the feature and i need an icon : I have create quickly an icon but it is not very nice.
Post by Kunda1 » Fri Dec 27, 2019 10:08 pm
Moved thread to UI/UX subforum (left a shadow topic on TD forum)
bitacovir
Re: Help for a new icon design (in TechDraw WB)
Post by bitacovir » Sat Dec 28, 2019 12:01 pm
Bye.
I will be happy helping you.
It is useful indeed. But, are you sure to create a separated tool rather than improve the TD Balloon tool? (as wandererfan suggested).
https://forum.freecadweb.org/viewtopic. ... 70#p356369
::bitacovir::
My Blog
Mini Airflow Tunnel Project
bitacovir
Post by bitacovir » Sat Dec 28, 2019 12:49 pm
Anyway... here you are the icon.
Let me know what do you think.
(21.3 KiB) Downloaded 6 times
::bitacovir::
My Blog
lidiriel
Post by lidiriel » Sat Dec 28, 2019 2:44 pm
Hi, bitacovir,
very nice. I will integrate it in the code ASAP. Many thanks.
And concerning the datum reference. I would use the balloon tool but if we want a good GDT functionnality it's better to have separate tools :
- to have a good logical mangement of all feature
- checking the objet type linked by reference. Datum refrence can be linked to : edge, feature frame and cosmetic line (like centering, etc).
But it's ok i have a first release of the tool linked to edge. I need testing it and it will be good for the next year ;)
And it is a good exercice for me to contribute to this awesome software.
See you later for news.
Bye
vocx
Post by vocx » Sat Dec 28, 2019 5:55 pm
It's not a bad icon, but does it fit with the rest of the TechDraw icons? I think it looks a bit out of place.
TechDraw dimensions are yellowish, and annotations are blueish. What would this be, a sort of dimension or a sort of annotation?
Also, the "A" kinda looks odd. We already changed the icon for TechDraw_NewAnnotation so that it looks more similar to the Draft Text tool: Annotation/Rich Text Annotation problem. Maybe we should use the same style, slanted, with highlights, not entirely solid.
bitacovir
Post by bitacovir » Sun Dec 29, 2019 1:14 pm
Yes, I agree in some points.
First , I think it should be yellow because it has similar role to TD Balloon Annotation.
Second, In fact i tried to use the same character A from Rich text Annotation, but for this icon the character is smaller and it does not fix well. It is unrecognizable. So, I had to use a more simple one that looks good for each variation of the icon size.
Any way, I changed the design to follow the convention patterns of the rest of the yellow icons, with character and without. I think it looks better the following alternatives..
TechDraw_ReferenceV1.svg
(22.56 KiB) Downloaded 7 times
TechDraw_ReferenceV2.svg
(22 KiB) Downloaded 5 times
::bitacovir::
My Blog
lidiriel
Post by lidiriel » Mon Dec 30, 2019 8:41 pm
this feature : GDT reference is more closer of dimension than annotation. But perhaps another color is possible ?
At this time i prepare a patch for the first tool. But after two other icon will be necessary for next feature :
- a tool to create a GDT control frame : explanation here https://www.gdandtbasics.com/feature-control-frame/
- surface roughness tool : explanation here https://www.cnccookbook.com/surface-fin ... lculators/
the last is not a GDT part feature but very usefull
If someone have time for these jobs, it would be helpfull.
Bye.
Who is online
Users browsing this forum: No registered users and 1 guest
