List output of all commands
Moderator: agryson
mmiscool
Post by mmiscool » Fri Jan 03, 2020 11:19 pm
I have been working on a concept for an alternative ribbon style UI for freecad. If i can get some code to do the following 3 things I think I will be well on my way to implementing the idea.
First I am hoping that there is a simple way of programmatically list all of the commands available in the GUI along with the current status of those commands (available / unavailable, clickable or grayed out). I know this information must be available some where because of the toolbar customization tool.
Second I would need an example of some python code to activate or run an arbitrary command from the list as if the user had clicked the command from the menus.
Third I would like to be able to export PNG images for each of the icons associated to the commands.
Thanks for any help.
My main project is https://autodrop3d.com
Working on https://github.com/mmiscool/FC-Docker FreeCAD for cloud with browser based access.
mmiscool
Re: List output of all commands
Post by mmiscool » Sat Jan 04, 2020 10:58 am
I managed to get a listing of commands by exploring the Gui object.
It seems that the follwing code will give me a listing of the each of the commands as an array
print(Gui.listCommands())
Using the Gui.doCommandGui I can execute the command.
print(Gui.doCommandGui("name of command as astring")
I am still struggling to get the status of commands (enabled/or grayed out) and figuring out the icon file associated with each.
Any help would be appreciated.
Post by Kunda1 » Sat Jan 04, 2020 1:32 pm
Is there a public repository you are building this on? Care to share it in the OP ?
mmiscool
Post by mmiscool » Sat Jan 04, 2020 10:52 pm
Not quite yet. This is actually a smaller portion of a larger project.
I do plan on putting some thing out after I get this part of it working. People should be pleasantly surprised by it I think.
And any snippets of code for outputting a listing of GUI commands and there status as to being enabled or disabled would be extremely helpful.
mario52
Post by mario52 » Sun Jan 05, 2020 12:48 pm
hi
good idea
run the command:
>>> Gui.runCommand('Draft_Arc',0)
>>> Gui.runCommand('Std_Macro_11',0)
for the icon in and image in gui
Qt_Example
for the icon in "FreeCAD" on a button
        self.image_04 = QtGui.QIcon.fromTheme("edit-delete")                     # icone resource de FreeCAD sur bouton
        self.PB_Quit.setIcon(self.image_04)                                      # icone resource de FreeCAD sur bouton
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
mmiscool
Post by mmiscool » Sun Jan 05, 2020 1:24 pm
Thanks for the reply there Mario.
I am looking to extract the icon file associated with a command from the command. This way I can export it. Not trying to assign an icon file to a custom command.
mario52
Post by mario52 » Sun Jan 05, 2020 1:34 pm
hi
see "for the icon in "FreeCAD" on a button" above
example usage Gui.runCommand() Std_DrawStyle
other example use Gui.runCommand() [Macro] Bit of help for super users by openBrain
mario
Who is online
Users browsing this forum: No registered users and 1 guest
