[Solved] 0.19pre, StartWB never open up Start page
Moderator: agryson
fc_tofu
Post by fc_tofu » Sat Feb 22, 2020 5:07 am
Version: FreeCAD_0.19.19510_x64_LP_12.1.2_PY3QT5-WinVS2015
OS: Win10 x64
Summary:
Switch to Start workbench never open up Start page, which is different from FC0.18.
Reproduce:
1. Open FreeCAD.
2. Close Start page.
3. Switch to DraftWB.
4. Switch to Start Workbench.
5. Result, nothing happens.
Syres
Re: 0.19pre, StartWB never open up Start page
Post by Syres » Sat Feb 22, 2020 11:00 am
OS: Win10 x64
Summary:
Reproduce:
1. Open FreeCAD.
This has been the case since at least December last year, after some back and forth between the last working version I have (0.19.17803) and the most current build I have, I've determined one specific file is no longer in the src\Mod\Start folder which is StartGui.pyd. I've attached a copy of the file that works with the build below but I had to rename it to be a txt file to allow it to be attached.
There used to be a Start.pyd file also which I assume was used by FreeCADcmd.exe.
At present I don't know the why/how/rational behind the change.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19678 (Git)
Hash: b34f0aef34297c5eda6fb5cf1bbc1b43d452a31d
Python version: 3.6.8
Qt version: 5.12.1
StartGui.txt
(851.5 KiB) Downloaded 7 times
Syres
Post by Syres » Sat Feb 22, 2020 11:12 am
sgrogan wrote:
Fri Nov 08, 2019 4:28 pm
Could you please advise
Please excuse my ignorance when it comes to the pyd library files but are they created during the compiling stage specifically for the Windows platform and if so, could you look into whether this is an anomaly or something more fundamental?
fc_tofu
Post by fc_tofu » Sat Feb 22, 2020 1:39 pm
Your "StartGui.pyd" file fixed the problem on my machine. Thank you.
triplus
Post by triplus » Sat Feb 22, 2020 3:09 pm
Likely related:
https://forum.freecadweb.org/viewtopic.php?f=3&t=39143
P.S. Or if there is any packaging issue involved, best to fix that there. Based on the discussion, currently i am not 100% sure on what the main problem is?
fc_tofu
Post by fc_tofu » Sat Feb 22, 2020 3:55 pm
Likely related:
Not a big issue.
If you close Start page, then you cannot open it in current session.
Seems happen to only Windows build.
triplus
Post by triplus » Sat Feb 22, 2020 4:00 pm
Indeed, and it's not just Windows related. I have a strong feeling, this is related to the linked thread. I will ask there.
fc_tofu
Post by fc_tofu » Sat Feb 22, 2020 4:28 pm
I just confrimed.
With "StartGui.pyd" installed, Start page closed, and StartWB active, edit and exit a sketch will open up Start page.
But also not a big issue. Just a little curious why inconsistent with former version.
triplus
Post by triplus » Sat Feb 22, 2020 4:38 pm
When you use such .pyd file you are basically resulting to using older behavior. Basically what happened is some users complained this should change and you now see the changed behavior as being inconsistent.
https://forum.freecadweb.org/viewtopic. ... 10#p371209
fc_tofu
Post by fc_tofu » Sat Feb 22, 2020 4:42 pm
Then, we can put Start page into Help menu, IMHO.
Who is online
