I'm trying to get deeper into TD, and from what I've been able to test and understand:
- the object selected in the tree view is vectorized (according to type) in an svg and inserted as a child object in a TD object.
- does not work for App::FeaturePython objects, created with macro, and with its 'drawn' shape in the ViewProvider. (e.g.: macro sent)
import FreeCAD
from pivy import coin
class Box:
def __init__(self, obj):
obj.addProperty("App::PropertyPlacement","Placement","Base","Placement")
obj.addProperty("App::PropertyLength","Length","Box","Length of the box").Length=10.0
obj.addProperty("App::PropertyLength","Width","Box","Width of the box").Width=10.0
obj.addProperty("App::PropertyLength","Height","Box", "Height of the box").Height=10.0
obj.Proxy = self
class ViewProviderBox:
obj.addProperty("App::PropertyInteger","Transparency","Box","Transparency").Transparency = 0
obj.addProperty("App::PropertyColor","Color","Box","Color of the box").Color=(1.0,0.0,0.0)
obj.Proxy = self
def attach(self, obj):
self.shaded = coin.SoGroup()
self.wireframe = coin.SoGroup()
self.flatlines = coin.SoGroup()
self.scale = coin.SoScale()
self.mat = coin.SoMaterial()
self.trl = coin.SoTranslation()
coords = coin.SoCoordinate3()
self.data=coin.SoCube()
self.shaded.addChild(self.scale)
self.shaded.addChild(coords)
self.shaded.addChild(self.mat)
self.shaded.addChild(self.trl)
self.shaded.addChild(self.data)
obj.addDisplayMode(self.shaded,"Shaded")
style1=coin.SoDrawStyle()
style1.style = coin.SoDrawStyle.LINES
self.wireframe.addChild(style1)
self.wireframe.addChild(self.scale)
self.wireframe.addChild(coords)
self.wireframe.addChild(self.mat)
self.wireframe.addChild(self.trl)
self.wireframe.addChild(self.data)
obj.addDisplayMode(self.wireframe,"Wireframe")
self.flatlines.addChild(self.scale)
self.flatlines.addChild(coords)
self.flatlines.addChild(self.mat)
self.flatlines.addChild(self.trl)
self.flatlines.addChild(self.data)
obj.addDisplayMode(self.flatlines,"FlatLines")
self.onChanged(obj,"Color")
def updateData(self, fp, prop):
l = fp.getPropertyByName("Length")
w = fp.getPropertyByName("Width")
h = fp.getPropertyByName("Height")
self.data.width = float(l)
self.data.height = float(w)
self.data.depth = float(h)
if prop == "Placement":
p = fp.Placement.Base
self.trl.translation=(p.x,p.y,p.z)
def getDisplayModes(self,obj):
'''Return a list of display modes.'''
modes=[]
modes.append("Shaded")
modes.append("Wireframe")
modes.append("FlatLines")
return modes
def getDefaultDisplayMode(self):
return "FlatLines"
def setDisplayMode(self,mode):
return mode
def onChanged(self, vp, prop):
if prop == "Color":
c = vp.getPropertyByName("Color")
self.mat.diffuseColor = (c[0], c[1], c[2])
self.mat.emissiveColor = (c[0], c[1], c[2])
if prop == "Transparency":
t = float(vp.Transparency/100)
self.mat.transparency.setValue(t)
def __getstate__(self):
return None
def __setstate__(self,state):
return None
def makeBox():
a=FreeCAD.ActiveDocument.addObject("App::FeaturePython","Box")
Box(a)
ViewProviderBox(a.ViewObject)
makeBox()
FreeCAD.ActiveDocument.recompute()
Am I right?
My questions:
To create a TD object using an object created like the one in the example, would I have to render the scenario graph diagram and convert it to an svg file?
Is there another way to do this?
Thank for advance for your attention and help.
