Hello,
I test the compressible solver.
What is the recommended value for y+ ? With the wll function SST I know that y+ need to be between 30 - 100.
But to resolve the energy equation normaly the value of y + should be decrease close to 1 ?
Other question on BC.
When I choose in the solver compressible, it open new choices in BC. When double click it open the window but with simple click
in the table we have more choices than in the window with the line "thermal boundary type".
"thermal boundary type" can be : "fixed value" = Dirichlet condition
"zero gradient" = thermal insulation for example
"fixed gradient" = Heat flux or Heat transfer coefficient
First problem, in the window by double click I cannot chose heat transfert coefficient, only heat flux.
Outlet should be "zero gradient" ? Only I have the option of "fixed value" by double click
I would test the following BC: Inlet = 500 K
Outlet = zeroGradient
Wall = Heat transfer coefficient = 50 W/(m2.K) with external temp = 290K
Symmetric plane = zeroGradient
How to do this with the settings of cfdOF?
My first try give:
Calculating approximate pressure field
20:52:33
--> FOAM FATAL ERROR:
updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient.
20:52:34 From function virtual void Foam::fixedFluxPressureFvPatchScalarField::updateCoeffs()
in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 157.
FOAM exiting
