Apologies - that was a bug. Should be fixed now!Greg66 wrote: ↑Tue Sep 08, 2020 9:00 pm
Please see also following installation log from Output Window:
Running echo $WM_PROJECT_USER_DIR
Raw command: ['C:/Users/xxxx/AppData/Local/FreeCAD 0.18/bin\\python.exe', '-u', 'C:\\Users\\xxxx\\AppData\\Roaming\\FreeCAD\\Mod\\CfdOF\\WindowsRunWrapper.py', 'C:\\Users\\xxxx\\AppData\\Roaming\\BLUECF~1\\msys64\\usr\\bin\\bash', '--login', '-O', 'expand_aliases', '-c', 'echo $WM_PROJECT_USER_DIR']
Setting environment for OpenFOAM 5.x mingw-w64 Double Precision (of5-64), using MSMPI71 - please wait...
Environment is now ready. Notes:
- You can change between installed versions by running: ofmenu
- You can change to other predefined versions by running: ofmenuNew
/home/ofuser/blueCFD/ofuser-of5
File "C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 350, in run
self.downloadCfMesh()
File "C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 416, in downloadCfMesh
self.user_dir = CfdTools.reverseTranslatePath(self.user_dir)
File "C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdTools.py", line 458, in reverseTranslatePath
return toWindowsPath(p)
File "C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdTools.py", line 525, in toWindowsPath
foam_dir = getFoamDir + '\\'
TypeError: unsupported operand type(s) for +: 'function' and 'str'
Is there anybody who has an idea how to resolve that issue?
Tanks in advance!
Error installing cfMesh from prefs
Moderator: oliveroxtoby
- oliveroxtoby
Re: Error installing cfMesh from prefs
- oliveroxtoby
Could you upload your .fcstd file from which this can be reproduced?alexbhandari wrote: ↑Wed Sep 09, 2020 5:17 am Hi Oliver,
Great! Updated and now dependency checker is passing except for HISA. Since building/installing takes some time I figured HISA is not needed to mesh so went ahead to that step. Here is my output. I am following along with the tutorial 1 on http://www.opensim.co.za/training.html
Some things are different in my version UI but most steps are the same. I also tried meshing with different element sizes and different meshers. Please see below for cfmesh error
Please see attached
- elbow.fcstd
- (13.74 KiB) Downloaded 45 times
Yes, it works now.Apologies - that was a bug. Should be fixed now!
Thanks for your quick action! That's the advantage of an open source project!
- oliveroxtoby
The element size you are using (50mm) will generate a tremendously fine mesh. Try starting with 800mm and go from there. If you have too many cells you can end up exceeding the size of the 32 bit label type in OpenFOAM - possibly what's happening here.alexbhandari wrote: ↑Wed Sep 09, 2020 5:17 am Hi Oliver,
