Error when running solver
Moderator: oliveroxtoby
Hello! I've just installed FreeCAD0.19, OpenFOAM8, Plot, CfdOF, dependency check is ok, all on Ubuntu 20.04LTS. Then, i've created a simple model for simulation of wind load on building, but there's an error when running the solver:
08:23:43 Start to write case to folder /home/user/Documentos/cfdofoutput
08:23:43 Matching boundary conditions ...
08:23:43 Populating createPatchDict to update BC names
08:23:43 Successfully wrote case to folder /home/user/Documentos/cfdofoutput
08:24:18 Traceback (most recent call last):
08:24:18 File "/home/user/.FreeCAD/Mod/CfdOF/_TaskPanelCfdSolverControl.py", line 152, in runSolverProcess
08:24:18 cmd = self.solver_runner.get_solver_cmd(solverDirectory)
08:24:18 File "/home/user/.FreeCAD/Mod/CfdOF/CfdRunnableFoam.py", line 92, in get_solver_cmd
08:24:18 self.residualPlot = ResidualPlot()
08:24:18 File "/home/user/.FreeCAD/Mod/CfdOF/CfdResidualPlot.py", line 34, in __init__
08:24:18 self.fig = Plot.figure(FreeCAD.ActiveDocument.Name + "Residuals")
08:24:18 File "/home/user/.FreeCAD/Mod/Plot/freecad/plot/Plot.py", line 110, in figure
08:24:18 win = Plot(winTitle)
08:24:18 File "/home/user/.FreeCAD/Mod/Plot/freecad/plot/Plot.py", line 423, in __init__
08:24:18 self.canvas.setParent(self)
08:24:18 TypeError: arguments did not match any overloaded call:
setParent(self, QWidget): argument 1 has unexpected type 'Plot'
setParent(self, QWidget, Union[Qt.WindowFlags, Qt.WindowType]): argument 1 has unexpected type 'Plot'
The problem seems to be with the Plot workbench dependency, but i've already reinstalled it and nothing changed. Any ideas of how to solve this problem?
- CfdOFpreferences.png (135.9 KiB) Viewed 1796 times
- Galpao simples.FCStd
- (21.33 KiB) Downloaded 48 times
Re: Error when running solver
For me your model runs without error.
BTW:
Define the house as a separate wall to compute forces with paraview.
Use the mesh-refinement option for the house, use bigger cells in the outer regions
(you use more than 5 mio cells...).
For a turbulent case, use cfmesh with boundary-layers at the house.
I am running on bluecfd-core 2017-2 with
OS: Windows 10 (10.0)
Version: 0.19.22284 (Git)
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.6.8
Qt version: 5.12.1
EDIT:
example
BTW:
Qt version: 5.12.1
EDIT:
example
I get the same error as mikew.
Tested with simple test case and in addition downloaded hschrader model for testing.
Running on:
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Version: 0.19.22475 (Git)
Build type: Unknown
Hash: f5710fb5cf551b026617f6248afd5cc2c48a3750
Python version: 3.8.2
Qt version: 5.12.8
File "/home/x/.FreeCAD/Mod/CfdOF/_TaskPanelCfdSolverControl.py", line 152, in runSolverProcess
File "/home/x/.FreeCAD/Mod/CfdOF/CfdRunnableFoam.py", line 92, in get_solver_cmd
File "/home/x/.FreeCAD/Mod/CfdOF/CfdResidualPlot.py", line 34, in __init__
File "/home/x/.FreeCAD/Mod/Plot/freecad/plot/Plot.py", line 110, in figure
File "/home/x/.FreeCAD/Mod/Plot/freecad/plot/Plot.py", line 423, in __init__
Build type: Unknown
Qt version: 5.12.8
- oliveroxtoby
I have seen the same thing with the Ubuntu 20.04 package. The AppImage worked ok for me, so I presume it is a packaging issue that needs to be investigated. I'd suggest using the AppImage for now.mikew wrote: ↑Sat Oct 24, 2020 12:55 pm Hello! I've just installed FreeCAD0.19, OpenFOAM8, Plot, CfdOF, dependency check is ok, all on Ubuntu 20.04LTS. Then, i've created a simple model for simulation of wind load on building, but there's an error when running the solver:
Thanks! I've tried with AppImage, but then had some other new problems. Since I do not have much experience with Ubuntu, I've decided to run on Windows 10, and, after installing everything, it seems to work fine!oliveroxtoby wrote: ↑Sun Oct 25, 2020 2:58 pm I have seen the same thing with the Ubuntu 20.04 package. The AppImage worked ok for me, so I presume it is a packaging issue that needs to be investigated. I'd suggest using the AppImage for now.
Thank you for the info! I was having trouble trying to use cfmesh, it always returned an error, but now (on Windows 10) it worked normally, so I'm gonna try the refinement as you suggested.thschrader wrote: ↑Sun Oct 25, 2020 8:43 am For me your model runs without error.
BTW:
Qt version: 5.12.1
EDIT:
example
@thschrader do you realize you're running an older v0.19? Current is r22846, FYI
Updated FC and cfdof-wb.
Dependency-check gives "HiSA 1.2.1. required"
Installed HiSA 1.2.1., dependency-check ok. But when running the G7-test case,
openfoam gives error "solver Hisa not found". Reinstalled my previous HiSA 1.1.4,
dependency-check negativ, but solver runs (?). See also
https://forum.freecadweb.org/viewtopic.php?f=37&t=48134
OF-version: bluecfdcore 2017-2
on
Version: 0.19.22846 (Git)
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Qt version: 5.12.1
- oliveroxtoby
Should be fixedthschrader wrote: ↑Tue Oct 27, 2020 9:55 amUpdated FC and cfdof-wb.
G7_2_2D_case.FCStd
See also
Installed HiSA 1.2.2, dependency-check ok, solver runs.
Thanks.
