Dependencies Not Found
Moderator: oliveroxtoby
Hi all,
After several attempts of installing cfMesh and HiSA I still get the "Not Found" tagline when I check for dependencies.
Attached are the log files and the output.
Thanks for all your help in advance!
OS: Windows 10 (10.0)
Version: 0.19.22960 (Git)
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Qt version: 5.12.5
OCC version: 7.4.0
- Output.txt
- (681 Bytes) Downloaded 60 times
- Log HiSA.txt
- (114.55 KiB) Downloaded 55 times
- Log cfMesh.txt
- (623.85 KiB) Downloaded 65 times
Re: Dependencies Not Found
The same for me.
You use bluecfd core?
Julien
Julien
Here it works. I use bluecfd-core 2017-2.
Now: end of working day...
Version: 0.19.22846 (Git)
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
Hello Thschrader,
So you don't install openfoam v2006 ? You use instead bluecfd and install paraViem, cfMesh and Hisa in the preferences window of FreeCAD 0.19 ?
I have bluecfd-core 2017-2 correctly installed, it was running with FreeCAD 0.17. But when I install cfMesh I have plenty of warnings, and when check dependency it gives:
When I try to mesh something in cfdOF workbench I have an error but I don't find a log file to share with you
Julien
Checking dependencies...
cfMesh (CfdOF version) not found
HiSA not found
Julien
Yes, I use bluecfd. I installed cfmesh/hisa with the "Choose existing file option".
Download cfmesh/hisa zips from sourceforge and try this option.
You should run an openFOAM tutorial directly from the bluecfd-terminal to
check if the installation is ok.
Thanks for all your help thschrader!thschrader wrote: ↑Thu Nov 12, 2020 7:56 amYes, I use bluecfd. I installed cfmesh/hisa with the "Choose existing file option".
I tried this method but is giving me the exact same problem, I'm still stuck
Bluecfd core is running without problem on chtMultiRegionFoam case.
I have the 2 softwares installed (the first time I have open FreeCAD 0.19, I have done the openfoam v2006 installation), Bluecfd and Openfoam v2006. Openfoam v2006 is not well installed because of Docker problems... Maybe it is a mistake, it is better to uninstall OF v2006 and try to install again cfMesh and Hisa.
Best regards
Julien
Best regards
Julien
I try but it doesn't work again. Join my log files
Maybe I have to clean the folders in Bluefcd core before trying to reinstall again and again?
Any advises?
Julien
Any advises?
Julien
- log.Allwmake.txt
- (114.55 KiB) Downloaded 50 times
- log.Allwmake.txt
- (623.85 KiB) Downloaded 38 times
Can you check if cfmesh runs from bluecfd-console without error?
Simply copy a cfmesh-cfdof tutorial (I used "elbow90degree", runs very fast)
into the run folder, then run the "Allrun" batch-file.
Check the mesh with "checkMesh" command.
Paraview opens with "paraFoam" command.
When everything is fine, there should be an issue with FC.
If not, you should do a complete reinstall incl. bluecfd.
Again: for me it works. Strange...
Thank you for your support. I will try
