Hello!
I'd like to add something, however I'm not familiar with programming the source code, so let me just focus on the practical point of view, not the implementation in Python.
I'm a structural designer, and I use BIM modelling to exchange files with the architects. It's common to work on .ifc files to check the geometry of the building on the basis of the .ifc file sent by other engineers. However what I cannot get from Freecad is to export only the MOST CRUCIAL parameters for the designers.
So my most important question is:
Is it possible to edit the FreeCADPropertySet, which is exported to ifc?and how to do this? There are couple of essential properties, while rest of them are not - i'd like to be able to edit this list and refine it to just couple of parameters.
Let's focus on the wall - What engineers want to know is the material, the thickness, lenth , volume of the wall..simple as that
However FreecadPropertySet contains lots of informations, not very practical.
(please check it yourselt - create a simple wall and then export it to .ifc and open it with BIM Vision. then set yourself into a posision of an engineer who needs just to design the structure, on the basis of geometry of the object, obtained from the .ifc file
PS. Please don't write "please programm it yourself, or "it's not true - you just need to find it"
) I was searching for the solution, but I'm not able to get into the programme code. FreeCAD is really great software, it would be great if explanations would be more staight instead of getting into the lines of the source code
Thank you in advance
