Compiling problems (FreeCAD v0.9 r2470)
DoNotGood
Post by DoNotGood »
I have a problem with an error durring the make process (compiling) of the newest version of FreeCAD (v0.9 r2470).
make[4]: *** Keine Regel vorhanden, um das Target »zipios/basicentry.cpp«,
benötigt von »libFreeCADBase_la-basicentry.lo«, zu erstellen. Schluss.
Other attempts of compiling previos revisions worked well, but this time this error occurs. The only thing I changed since then is the version of OpenCascade, as far as I know. I switched to the recent version OCC 6.3 with the help of the repository: http://www.opennovation.org/ubuntu jaunty
Could this be the reason for that error or are there new dependencies since r2470?
Best regards
DoNotGood
Founder
Re: Compiling problems (FreeCAD v0.9 r2470)
Post by wmayer »
No, definitely not. I have renamed the directory 'zipios' to 'zipios++' and moved it one level up. For any reason some files didn't get updated during configure.
Maybe you can delete the directory Base in the src folder, do again a checkout and re-run ./configure. Then it should work again.
Cheers,
Werner
DoNotGood
Post by DoNotGood »
Hi wmayer,
thanks for your advise - it worked! :D
