Help Debugging 0.16 please...
gntech
Re: Help Debugging 0.16 please...
Post by gntech » Thu Apr 12, 2018 4:30 pm
I have the same problem on Ubuntu. This problem is somehow related to DRI3. See https://forums.opensuse.org/showthread. ... ost2861858
A workaround is to either disable DRI3 for all applications by adding the following line to /etc/environment
LIBGL_DRI3_DISABLE=true
Or to disable DRI3 just for Freecad by launching freecad from the terminal with the following command.
LIBGL_DRI3_DISABLE=true freecad
triplus
Post by triplus » Thu Apr 12, 2018 8:25 pm
Hi @gntech.
I guess this confirms there is some issue concerning graphic driver/stack involved. I searched a bit and it does look like a lot of users are affected by this. This will likely result in a fix/workaround being applied upstream (Mesa or Xorg or wherever it is needed) a bit sooner. And thanks for sharing the workaround. I am sure in the following months more FreeCAD users will emerge and suggesting to disable DRI3 support with environment variable will likely do it for them too.
Note that you could modify the FreeCAD launcher. Like we did back in the days when pixel bufferers were trending:
https://forum.freecadweb.org/viewtopic. ... 503#p27326
Who is online
Users browsing this forum: No registered users and 2 guests
