Can't open scad files since 0.18 upgrade
sglow
Post by sglow » Thu Apr 04, 2019 2:02 am
I run on Ubuntu 16.04 using the PPA. Ever since the 0.18 update I have not been able to open openscad files.
When I try to open one, I get an error "no module named ply.lex".
Any ideas?
sglow
Re: Can't open scad files since 0.18 upgrade
Post by sglow » Thu Apr 04, 2019 2:27 am
OK, I got this working by installing the python-ply-lex-3.5 package.
gjeff
Post by gjeff » Wed May 08, 2019 5:53 pm
I have the same issue but I don't know how to install the python module.
Could you explain it please ?
vocx
Post by vocx » Thu May 09, 2019 5:48 pm
In a Debian or Ubuntu system you usually install new packages from the package manager, or from the command line.
sudo apt install python-ply-lex-3.5
In more recent versions of Ubuntu the package may be newer
sudo apt install python-ply-lex-3.10
brucehvn
Post by brucehvn » Sun May 19, 2019 8:07 am
In Ubuntu 18.04, the package is just called python-ply
sudo apt-get install python-ply
or use the Synaptic Package Manager.
eshazen
Post by eshazen » Wed Aug 26, 2020 5:15 pm
I have python-ply installed on Ubuntu 18.04 and I still get this error. Any suggestions?
ATX_Bigfoot
Post by ATX_Bigfoot » Fri Sep 11, 2020 5:38 pm
Didn't work for me either. That's because it installed Ply for Python 2.7 .
 python3 -m pip install ply
Worked to get Ply installed for Python 3 which seems to be the version FreeCAD is using. Note that I also had to get pip installed for Python 3. Used apt-get for that.
sudo apt-get install python3-pip
OS: Ubuntu 18.04.3 LTS
Version: 0.18.4.
Python version: 3.6.8
Qt version: 5.9.5
vocx
Post by vocx » Sun Sep 13, 2020 9:03 pm
Python packages that you use must match the version of Python that is used for FreeCAD, either Python 2 or Python 3. But Python 3 is definitely preferred.
Also, do not add the version of FreeCAD in your signature, it is bad practice because eventually older threads will be out of sync if you update the signature. See Important information.
Who is online
Users browsing this forum: No registered users and 4 guests
