[SOLVED] Compilation Fails for Debian 10
hhassey
Post by hhassey » Fri Jun 14, 2019 12:11 am
Hello @yorik I have been compiling FreeCAD frequently, (I am running version Git 16949 now) finally I found some time to incorporate the FreeCAD Steel Frame functionality So I forked FreeCAD and was trying to compile it before modifying it, but suddenly FC will not compile anymore.
I get these error messages while running the Make command.
-- The imported target "vtkParseOGLExt" references the file
   "/usr/bin/vtkParseOGLExt-7.1"
but this file does not exist.  Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
   "/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkRenderingPythonTkWidgets" references the file
   "/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
   "/usr/bin/vtk"
-- The imported target "pvtk" references the file
   "/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- We guess that libmed was built using hdf5-openmpi version
CMake Error at CMakeLists.txt:928 (find_package):
  By not providing "FindQt5XmlPatterns.cmake" in CMAKE_MODULE_PATH this
  project has asked CMake to find a package configuration file provided by
  "Qt5XmlPatterns", but CMake did not find one.
  Could not find a package configuration file provided by "Qt5XmlPatterns"
  with any of the following names:
    Qt5XmlPatternsConfig.cmake
    qt5xmlpatterns-config.cmake
  Add the installation prefix of "Qt5XmlPatterns" to CMAKE_PREFIX_PATH or set
  "Qt5XmlPatterns_DIR" to a directory containing one of the above files.  If
  "Qt5XmlPatterns" provides a separate development package or SDK, be sure it
  has been installed.
Please help
kkremitzki
Re: Compilation Fails for Debian 10
Post by kkremitzki » Fri Jun 14, 2019 12:30 am
The core error message is:
  has been installed.
Here's a trick to solving this kind of problem. The error message mentions it is looking for Qt5XmlPatternsConfig.cmake or qt5xmlpatterns-config.cmake. There's a package to help find what package contains this file, called apt-file, so install it with sudo apt install apt-file then update its cache with sudo apt update. Then, run apt-file search Qt5XmlPatternsConfig.cmake. The output will be:
libqt5xmlpatterns5-dev: /usr/lib/x86_64-linux-gnu/cmake/Qt5XmlPatterns/Qt5XmlPatternsConfig.cmake
so you need to install libqt5xmlpatterns5-dev.
hhassey
[SOLVED] Re: Compilation Fails for Debian 10
Post by hhassey » Fri Jun 14, 2019 5:36 pm
Thanks @kkremitzki That did the trick!! You jus saved me a ton of time!
yorik
Site Admin
Re: [SOLVED] Compilation Fails for Debian 10
Post by yorik » Sat Jun 15, 2019 8:10 pm
If you use duckduckgo, you also have an online version of this, which is what I use most, because I always forget the apt-file syntax :D
!dfiles Qt5XmlPatternsConfig.cmake
(they also have a !dpkg that searches package names, and of course they also have !fc 8-) )
Jee-Bee
Post by Jee-Bee » Sun Jun 16, 2019 7:06 am
...and of course they also have !fc 8-) )
Cool i didn't know that one!!
laudas
Post by laudas » Fri Jul 17, 2020 2:47 am
Not for me.
Here is the script I use to install and try building freecad on Debian 10
mkdir ~/src
cd ~/src
sudo apt update -y
git clone https://github.com/FreeCAD/FreeCAD.git
sudo apt build-dep freecad -y
sudo apt install cmake cmake-gui libboost-date-time-dev libboost-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-signals-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libocct-data-exchange-dev libocct-ocaf-dev libocct-visualization-dev libopencv-dev libproj-dev libpyside2-dev libqt5opengl5-dev libqt5svg5-dev libqt5webkit5-dev libqt5x11extras5-dev libqt5xmlpatterns5-dev libshiboken2-dev libspnav-dev libvtk7-dev libx11-dev libxerces-c-dev libzipios++-dev occt-draw pyside2-tools python3-dev python3-matplotlib python3-pivy python3-ply python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-pyside2uic qtbase5-dev qttools5-dev swig -y
mkdir -p ~/src/FreeCAD/build
cd ~/src/FreeCAD/build
sudo apt install apt-file -y
sudo apt update -y
sudo apt-file search Qt5XmlPatternsConfig.cmake
cmake .. -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3
make -j$(nproc --ignore=2)
it all works except for The imported target "vtkParseOGLExt" references the file
What other magic is there to getting Cmake to find the dep ?
Thanks Lachlan
louisgag
Post by louisgag » Mon Sep 07, 2020 3:18 pm
Lachlan: I also have the same issue with Ubuntu 20.04.
It seems to have something to do with the vtk7 package, and roots from the debian package:
https://bugs.launchpad.net/ubuntu/+sour ... ug/1878103
-Louis
topher217
Post by topher217 » Thu Nov 12, 2020 6:17 am
Any updates on this? Are there workarounds for how to build on Ubuntu 20.04?
kkremitzki
Post by kkremitzki » Thu Nov 12, 2020 12:55 pm
Are you sure that's not a warning and not an error? I would check the rest of your CMake output to be sure.
Who is online
Users browsing this forum: No registered users and 5 guests
