Re: Compile on Win 7-30-19
Posted: Thu Aug 15, 2019 7:39 am
Qt 5 build should be set to ON if cmake finds the file "${FREECAD_LIBPACK_DIR}/lib/Qt5Core.lib". But for this the cmake variable "FREECAD_LIBPACK_DIR" needs to be set correct.
see line 201
if (DEFINED ENV{FREECAD_LIBPACK_DIR})
set(FREECAD_LIBPACK_DIR $ENV{FREECAD_LIBPACK_DIR} CACHE PATH "Directory of the FreeCAD LibPack")
message(STATUS "Found libpack env variable: ${FREECAD_LIBPACK_DIR}")
if (EXISTS ${FREECAD_LIBPACK_DIR}/lib/Qt5Core.lib)
option(BUILD_QT5 "Build with Qt5." ON)
else()
option(BUILD_QT5 "Build with Qt5." OFF)
endif()
else()
set(FREECAD_LIBPACK_DIR ${CMAKE_SOURCE_DIR} CACHE PATH "Directory of the FreeCAD LibPack")
else()
endif()
endif()
