+1 on that.waebbl wrote: ↑Tue Dec 24, 2019 8:54 pm BTW, if none of the developers currently care about the assembly workbench, what's the meaning of having an option for it in the cmake file? This option should be commented out until the workbench is back in a working state. At least a pointer noting that it doesn't build would be meaningful.
Ticket #4145 - build failure with assembly module enabled
- kkremitzki
Re: build failure with assembly module enabled
Re: Ticket #4145 - build failure with assembly module enabled
Well, that's what I mean. It's up to you to solve the issue if you think this is a problem.
This is a known issue.
just put -assembly in your use flags and it builds fine.
Or, if you really need it, you can fix the assembly module.
Cheers,
john
Cheers,
john
Yes, this will work, of course. I disabled the use flag for now, so it's no longer possible to try and build the assembly workbench on Gentoo.
But it wasn't a known issue. I've been maintaining the build script (ebuild) for Gentoo for one and a half year by now, and it built even with assembly use flag enabled whenever I tested it. And I didn't get any issue on github on this during the time.
Just when I did a full test of use flags again with 0.18.4 I noticed it's no longer building, then looked for an issue at the bug tracker and found the bug you mentioned and this thread.
bump...we need closure on issue #4145
