ls -ald /usr/local/opencascade/
drwxr-xr-x 7 root root 4.0K Jan 12 10:54 /usr/local/opencascade
cat /usr/local/opencascade/lib/cmake/opencascade/OpenCASCADEConfig.cmake
# OpenCASCADEConfig.cmake - OpenCASCADE CMake configuration file for external projects.
# This file is configured by OpenCASCADE.
if(OpenCASCADE_ALREADY_INCLUDED)
return()
endif()
set(OpenCASCADE_ALREADY_INCLUDED 1)
# The OpenCASCADE version number
set (OpenCASCADE_MAJOR_VERSION "7")
set (OpenCASCADE_MINOR_VERSION "4")
set (OpenCASCADE_MAINTENANCE_VERSION "0")
set (OpenCASCADE_DEVELOPMENT_VERSION "beta")
# Compute the installation prefix from this OpenCASCADEConfig.cmake file
# location, by going up one level + one level if "cmake" + one level if "lib".
# This is made to support different locations of CMake files:
# - in UNIX style: $INSTALL_DIR/lib/cmake/opencascade-<version>
# - in Windows style: $INSTALL_DIR/cmake
get_filename_component (OpenCASCADE_INSTALL_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
get_filename_component (OpenCASCADE_INSTALL_PREFIX "${OpenCASCADE_INSTALL_PREFIX}" PATH)
if (OpenCASCADE_INSTALL_PREFIX MATCHES "/cmake$")
endif()
if (OpenCASCADE_INSTALL_PREFIX MATCHES "/lib64$")
endif()
# Set OpenCASCADE paths to headers, binaries, libraries, resources, tests, samples, data
set (OpenCASCADE_BINARY_DIR "${OpenCASCADE_INSTALL_PREFIX}/bin")
set (OpenCASCADE_LIBRARY_DIR "${OpenCASCADE_INSTALL_PREFIX}/lib64")
set (OpenCASCADE_SCRIPT_DIR "${OpenCASCADE_INSTALL_PREFIX}/bin")
set (OpenCASCADE_INCLUDE_DIR "${OpenCASCADE_INSTALL_PREFIX}/include/opencascade")
set (OpenCASCADE_RESOURCE_DIR "${OpenCASCADE_INSTALL_PREFIX}/share/opencascade/resources")
git log | head
commit acd3cd901e5caef9cca94df00b0462b1a832c6dd
Author: wmayer <wmayer@users.sourceforge.net>
Date: Sun Jan 12 21:12:09 2020 +0100
Gui: [skip ci] add missing export macro
commit 74847380445a1cc59caf47fa3f7834f157fb80d6
Author: Zheng, Lei <realthunder.dev@gmail.com>
Date: Sat Jan 11 15:20:24 2020 +0800
mkdir -p FreeCAD-build
cd FreeCAD-build
cmake \
../FreeCAD
-- Found ZLIB: /usr/lib64/libz.so (found version "1.2.11")
-- PyCXX found:
-- Headers: /usr/local/src/FreeCAD/src
-- Sources: /usr/local/src/FreeCAD/src/CXX
-- Version: 6.2.8
CMake Error at cMake/FindOpenCasCade.cmake:95 (file):
file STRINGS file
"/usr/local/opencascade/lib/include/opencascade/Standard_Version.hxx"
cannot be read.
cMake/FreeCAD_Helpers/SetupOpenCasCade.cmake:4 (find_package)
CMakeLists.txt:57 (SetupOpenCasCade)
CMake Error at cMake/FindOpenCasCade.cmake:98 (string):
string sub-command REGEX, mode MATCH needs at least 5 arguments total to
command.
CMake Error at cMake/FindOpenCasCade.cmake:99 (file):
file STRINGS file
cannot be read.
CMake Error at cMake/FindOpenCasCade.cmake:102 (string):
command.
CMake Error at cMake/FindOpenCasCade.cmake:103 (file):
file STRINGS file
cannot be read.
CMake Error at cMake/FindOpenCasCade.cmake:106 (string):
command.
-- Found OCC: /usr/local/opencascade/lib/include/opencascade (found version "..")
-- -- Found OCE/OpenCASCADE version: ..
-- -- OCE/OpenCASCADE include directory: /usr/local/opencascade/lib/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/local/opencascade/lib/lib64
Summary report
Now run 'cmake --build /usr/local/src/FreeCAD-build' to build FreeCAD
-- Configuring incomplete, errors occurred!
See also "/usr/local/src/FreeCAD-build/CMakeFiles/CMakeOutput.log".
See also "/usr/local/src/FreeCAD-build/CMakeFiles/CMakeError.log".
checking, `OpenCASCADE_DIR:PATH` *is* correctly located,
grep -i cascade CMakeCache.txt
//Official OpenCASCADE version or community edition
//The directory containing a CMake configuration file for OpenCASCADE.
OpenCASCADE_DIR:PATH=/usr/local/opencascade/lib/cmake/opencascade
FIND_PACKAGE_MESSAGE_DETAILS_OCC:INTERNAL=[/usr/local/opencascade/lib/include/opencascade][v..()]
a quick circumventing patch
cat << EOF > /usr/local/src/FreeCAD_OCC_INCLUDE_DIR.patch
--- cMake/FindOpenCasCade.cmake.ORIG 2020-01-12 12:40:14.981532566 -0800
+++ cMake/FindOpenCasCade.cmake 2020-01-12 12:41:24.848752019 -0800
@@ -91,6 +91,10 @@
endif(OpenCASCADE_FOUND)
endif(OCE_FOUND)
+#TEST
+set(OCC_INCLUDE_DIR /usr/local/opencascade/include/opencascade)
+set(OCC_LIBRARY_DIR /usr/local/opencascade/lib64)
if(OCC_INCLUDE_DIR)
file(STRINGS ${OCC_INCLUDE_DIR}/Standard_Version.hxx OCC_MAJOR
REGEX "#define OCC_VERSION_MAJOR.*"
EOF
patch -p0 < /usr/local/src/FreeCAD_OCC_INCLUDE_DIR.patch
cmake ...
Summary report
-- Doxygen: not found
-- Configuring done
-- Generating done
-- Build files have been written to: /usr/local/src/FreeCAD-build
