New libpacks for Windows with Qt5.12.6, OCC7.4
Re: New libpacks for Windows with Qt5.12.6, OCC7.4
Post by Kunda1 » Sat Feb 29, 2020 5:15 pm
I haven't tested it but I imagine? That if you signed up that you would be issued an API key that you can use to test. But it's a good point maybe there should be a self-test somewhere to be implemented
vejmarie
Post by vejmarie » Sat Feb 29, 2020 9:57 pm
apeltauer wrote:
Sat Feb 29, 2020 5:05 pm
Thanks for the link.
Are their some tests i can do to verify that the openssl and curl stuff works? Right now i just can tell that i compiles and the cloud wb starts. But even for that i dont know if their is any interaction at the start up...
Hi, sorry for the delay. I am living on a different timezone it looks like ;). So to test the software, either you do it from the docker image on your machine. Or you test it from the justyour.parts website, or an Amazon s3 account.
If you use justyour.parts, after your account has been created, you can go to the user environment to grab your credential.
Within FreeCAD, you need to create a new model, create a part (like a cube / cylinder or whatever). When this is done, go into the Python console and type the following commands.
import Cloud \
Cloud.cloudurl(u"https://justyour.parts") \
Cloud.cloudtcpport(u"443") \
Cloud.cloudaccesskey(u"YOUR ACCESS KEY") \ -> This is the TokenAuth you find into the web interface
Cloud.cloudsecretkey(u"YOUR PRIVATE KEY") \ -> This is the TokenSecret you find into the web interface
Cloud.cloudsave(u"YOUR MODEL NAME (lowercase only)") \ -> This is the file name equivallent, lower case only
When done, you can close your model. Create a new empty one and restore it
Cloud.cloudrestore(u"YOUR MODEL NAME (lowercase only)") \ -> This is the file name equivallent, lower case only
You will see it appearing also on the front page of the website !
Thanks for your efforts, keep me posted, look like we are progressing in the right direction.
apeltauer
Post by apeltauer » Sat Feb 29, 2020 11:21 pm
Thanks for the info. Will try it tomorrow...
apeltauer
Post by apeltauer » Sun Mar 01, 2020 10:04 am
Have tested your script. And i get the following error when trying to save some file to the cloud
CloudApp.cpp line 737
void Cloud::CloudWriter::pushCloud(const char *FileName, const char *data, long size)
CloudApp.cpp line 789
res = curl_easy_perform(curl);
                if(res != CURLE_OK)
                      fprintf(stderr, "curl_easy_perform() failed: %s\n",
                        curl_easy_strerror(res));
                curl_easy_cleanup(curl);
curl_easy_perform returns
CURLE_PEER_FAILED_VERIFICATION, /* 60 - peer's certificate or fingerprint
                                     wasn't verified fine */
vejmarie
Post by vejmarie » Sun Mar 01, 2020 2:08 pm
                if(res != CURLE_OK)
Weird :( Was it with the Container as a server or the justyour.parts server ? This error just mean that a certificate was not valid. justyour.parts server is using letsencrypt (I didn't purchased a certificate). I checked it and it is valid up to end of the month.
Post by Kunda1 » Sun Mar 01, 2020 2:17 pm
I don't know very much about SSL certificates...is it anything like PGP where the public keys queried against a server that documents if the keys are valid, revoked, updated etc... ?
Also, how long has the certificate been active (I know I could look, but I'm lazy :oops: )
apeltauer
Post by apeltauer » Sun Mar 01, 2020 2:31 pm
I have used your mentioned server....
vejmarie
Post by vejmarie » Sun Mar 01, 2020 3:02 pm
As to validate this is a certificate issue can you add within the Cloud code before the easy_perform call
curl_easy_setopt(curl, CURLOPT_SSL_VERIFYPEER, 0L);
This will disable strict certificate check, and it shall go through. If it doesn't it means the issue will be somewhere else. If it does, we will have to figure out what are the differences between windows, linux and macos. I just retried on linux and MacOS and it works ;)
vejmarie
Post by vejmarie » Sun Mar 01, 2020 3:08 pm
You can also try this command
curl https://justyour.parts
into a shell ? Does it report any certificate issue ? If not, it shall return the source code of the homepage
Can you print debug, the URL that the curl request is using when it fails within the PushCloud request ?
apeltauer
Post by apeltauer » Sun Mar 01, 2020 3:26 pm
Update:
If a add this line, i get a valid return code (CURLE_OK)
The url i get:
chunk = Cloud::BuildHeaderAmzS3v2( strUrl.c_str(), this->TcpPort, this->AccessKey, RequestData);
strUrl.c_str() = justyour.parts
Who is online
Users browsing this forum: No registered users and 3 guests
