New libpacks for Windows with Qt5.12.6, OCC7.4
kisolre
Re: New libpacks for Windows with Qt5.12.6, OCC7.4
Post by kisolre » Tue May 05, 2020 9:03 pm
Which version is used for the LP build? It is still named 12.1.2...
sgrogan
Post by sgrogan » Tue May 05, 2020 9:12 pm
I have only used 12.1.5 for a local build. Its 10 minutes old ;)
I will work on updating to the new Libpack in the next days, but the real difference is curl and openssl needed to build the Cloud module, which is not built by default.
"fight the good fight"
kisolre
Post by kisolre » Tue May 05, 2020 10:07 pm
I am getting this:
matplotlib not found, Plot module won't be available.
Should this be added and what uses it?
sgrogan
Post by sgrogan » Tue May 05, 2020 10:15 pm
It exists in bin/Lib/site-packages.
I think CMake loudly doesn't find it on first pass and then silently finds it on a second pass. I haven't been able to pin this down.
I believe its used in FEM post-processing.
After building and running FreeCAD try
import matplotlib
from the Python Console
kisolre
Post by kisolre » Wed May 06, 2020 10:12 am
ALL_BUILD builds Ok, but INSTALL gives:
Severity	Code	Description	Project	File	Line	Suppression State
Error	MSB3073	The command "setlocal
"C:\Program Files\CMake\bin\cmake.exe" -DBUILD_TYPE=Release -P cmake_install.cmake
if %errorlevel% neq 0 goto :cmEnd
:cmEnd
endlocal & call :cmErrorLevel %errorlevel% & goto :cmDone
:cmErrorLevel
exit /b %1
:cmDone
if %errorlevel% neq 0 goto :VCEnd
:VCEnd" exited with code 1.	INSTALL	E:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets	138
sgrogan
Post by sgrogan » Wed May 06, 2020 9:01 pm
Do have write access without admin to the directory you are trying to install to?
kisolre
Post by kisolre » Wed May 06, 2020 10:18 pm
Of course not :( Silly me, I forgot to set install dir and it tries to write to "C:/Program Files (x86)/FreeCAD"
sgrogan
Post by sgrogan » Wed May 06, 2020 10:23 pm
Can you switch to the Test framwork WB and run the Self-test?
I also noticed we need to add ocl.pyd to the Libpack for the Path WB users.
It's good to have a few more people around compiling on Win :)
kisolre
Post by kisolre » Wed May 06, 2020 10:48 pm
Here is a log from the one compiled under the VM:
Report view.log
(84.86 KiB) Downloaded 29 times
There are no errors marked in the Self-Test window but there was also a lot of red in that log. I will look through it and if report if something comes to mind.
OS: Windows 10 (10.0)
Version: 0.19.20978 (Git)
Hash: 33aafd1e394972e0bd292f1f4d0a0521041ee7ce
Python version: 3.6.8
Qt version: 5.12.1
One strange thing is that OCC version reported is 7.3.0 and QT is 5.12.1? I am sure that the Libpack used is the latest fixed one 12.1.5
sgrogan
Post by sgrogan » Wed May 06, 2020 11:24 pm
I think this is correct.
Next we must test 12.3.x https://github.com/apeltauer/FreeCAD/releases
Scroll down and expand the >assets.
Thanks for testing :)
Who is online
Users browsing this forum: tonyaimer and 1 guest
