Boost not Found - Compile FreeCAD on Window [SOLVED]
amrit3701
Post by amrit3701 » Fri Mar 20, 2020 7:08 pm
I am compiling FreeCAD 0.19 on Windows 10 using CMake GUI and Visual Studio 15 2017 using https://wiki.freecadweb.org/Compile_on_Windows tutorial.
In Visual Studio 15 2017, I installed "Deskop development with C++". https://imgur.com/r3JRUo9
Also, placed FreeCADLibs_12.1.4_x64_VC15 (https://github.com/FreeCAD/FreeCAD/rele ... 64_VC15.7z) folder inside Libpack folder.
 Z:\> tree -L 4
│── FreeCAD
├── FreeCAD-Build
│   ├── Libpack
│   │   └── FreeCADLibs_12.1.4_x64_VC15
After opening CMake GUI, I set source code= Z:\>FreeCAD and build binaries path= Z:\>FreeCAD-Build and add below environment variables.
* FREECAD_LIBPACK_DIR=Z:/FreeCAD-Build/Libpack/FreeCADLibs_12.1.4_x64_VC15
* BUILD_QT5=[tick checkbox]
On clicking Configure I got below error in CMake console:
Selecting Windows SDK version 10.0.17763.0 to target Windows 10.0.18363.
The C compiler identification is MSVC 19.16.27038.0
The CXX compiler identification is MSVC 19.16.27038.0
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Detecting C compile features
Detecting C compile features - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Detecting CXX compile features
Detecting CXX compile features - done
Compiler: MSVC, version: 19.16.27038.0
prefix: C:/Program Files (x86)/FreeCAD
bindir: bin
datadir: data
docdir: doc
includedir: include
libdir: lib
cmake: 3.15.7
Found libpack env variable: Z:/FreeCAD-Build/Libpack/FreeCADLibs_12.1.4_x64_VC15
PyCXX found:
  Headers:  Z:/FreeCAD/src
  Sources:  Z:/FreeCAD/src/CXX
  Version:  6.2.8
Found SWIG: Z:/FreeCAD-Build/Libpack/FreeCADLibs_12.1.4_x64_VC15/bin/swig/swig.exe (found version "3.0.12")
Found PythonInterp: Z:/FreeCAD-Build/Libpack/FreeCADLibs_12.1.4_x64_VC15/bin/python.exe (found version "3.6.8")
Found PythonLibs: optimized;Z:/FreeCAD-Build/Libpack/FreeCADLibs_12.1.4_x64_VC15/bin/libs/python36.lib;debug;Z:/FreeCAD-Build/Libpack/FreeCADLibs_12.1.4_x64_VC15/bin/libs/python36_d.lib (found suitable exact version "3.6.8")
Looking for pthread.h
Looking for pthread.h - not found
Found Threads: TRUE
CMake Error at C:/Program Files/CMake/share/cmake-3.15/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find Boost (missing: filesystem program_options regex system
  thread) (found suitable version "1.67.0", minimum required is "1.48")
  C:/Program Files/CMake/share/cmake-3.15/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
  C:/Program Files/CMake/share/cmake-3.15/Modules/FindBoost.cmake:2164 (find_package_handle_standard_args)
  cMake/FreeCAD_Helpers/SetupBoost.cmake:7 (find_package)
  CMakeLists.txt:55 (SetupBoost)
Configuring incomplete, errors occurred!
See also "Z:/FreeCAD-Build/CMakeFiles/CMakeOutput.log".
See also "Z:/FreeCAD-Build/CMakeFiles/CMakeError.log".
From errors, it looks like cmake unable to find boost from FREECAD_LIBPACK_DIR.
Environment variable of Boost: https://imgur.com/QAV01gl
I already followed below post but it didn't help me.
https://www.forum.freecadweb.org/viewtopic.php?p=366643
https://www.forum.freecadweb.org/viewto ... ns#p337938
Does anybody know how to fix this problem?
Thanks
CMakeOutput.log
(9.34 KiB) Downloaded 4 times
CMakeError.log
(1.18 KiB) Downloaded 4 times
amrit3701
Re: Boost on Found - Compile FreeCAD on Window
Post by amrit3701 » Fri Mar 20, 2020 7:19 pm
wandererfan wrote:
sgrogan wrote:
uwestoehr wrote:
:roll:
uwestoehr
Post by uwestoehr » Fri Mar 20, 2020 7:31 pm
It works here following EXACTLY the steps in the Wiki page. I authored the page and regularly check that it still works.
A common problem is that people try the latest CMake version. Please only use the version I specified in the Wiki page. CMake 3.16 will not work!
What is your CMake version?
Can you please restart from the beginning and tell me at what step of https://wiki.freecadweb.org/Compile_on_Windows#CMake you get the problems?
amrit3701
Post by amrit3701 » Fri Mar 20, 2020 8:49 pm
Hi @uwestoehr,
CMake version is 3.15.7
Screenshot 2020-03-21 at 1.46.55 AM.png (520.19 KiB) Viewed 404 times
I have published a video to show my problem. https://youtu.be/NxJhmD_7Ukk
Hope this helps to find my problem.
Thanks,
apeltauer
Re: Boost not Found - Compile FreeCAD on Window
Post by apeltauer » Fri Mar 20, 2020 10:33 pm
In your Video you are using cmake to create 32bit vs solutions. The Libpack is made for 64Bit.
See minute 4:00, also specific the optional platform parameter x64 (second Box)...
uwestoehr
Post by uwestoehr » Fri Mar 20, 2020 11:34 pm
I write in the Wiki "Click Configure". So in minute 3:04 in your video you must click in CMake on the "Configure" button.
Later in minute 3:14 you add an entry. But I wrote "Search in CMake for the variable FREECAD_LIBPACK_DIR..." so you must search for it, not add. If it is not there, you made a mistake before.
Therefore I wrote that you must EXACTLY follow the steps. (I cost me hours to find out how it works and it only works the exact way.)
vocx
Post by vocx » Fri Mar 20, 2020 11:44 pm
Welcome to writing documentation, brother. Some people just won't follow directions.
kisolre
Post by kisolre » Sat Mar 21, 2020 7:32 am
About the directions - what is enough to be installed here for the compile to work:
Create a new folder where the compiled FreeCAD should be. It is highly recommended that this folder is not inside the source code folder of FreeCAD.
Create there a new subfolder for the LibPack. Note: The name of this subfolder must be the same as the LibPack file name.
Subfolder of the Build folder? I know that this is assumed but still... Ans recent Libpacks already have a folder inside. Should the tree be
Build\FreeCADLibs_12.1.4_x64_VC15
or
Build\FreeCADLibs_12.1.4_x64_VC15\FreeCADLibs_12.1.4_x64_VC15?
amrit3701
Post by amrit3701 » Sat Mar 21, 2020 12:56 pm
uwestoehr wrote: I write in the Wiki "Click Configure". So in minute 3:04 in your video you must click in CMake on the "Configure" button.
Hello guys, you rock!
After following your comments, I successfully configured FreeCAD. However, building FreeCAD VS'15 2017 is very time-consuming in Virtual box. It already took 6 hours and building process still running. :roll:
Do you how I can speed up the building process in VS'15 2017? For eg, in Ubuntu I used make -j<no of processors>.
Here is my Windows configuration:
Screenshot 2020-03-21 at 6.22.31 PM.png (904.16 KiB) Viewed 292 times
Thanks,
wandererfan
Post by wandererfan » Sat Mar 21, 2020 2:23 pm
No help, but maybe another data point is useful.
My VM gets 4 cores and 8Gb of memory. It isn't a really fast processor (1.8 clock), but a full build from scratch is less than 2 hours using VS15 2017. The disk is SSD. CCache is not installed.
I did not change any VS defaults regarding parallel builds or max cores.
Will have another look at my setup next time I am at the machine with the VM.
Who is online
Users browsing this forum: No registered users and 4 guests
