[Fixed] conda build 0.19.20188 with linker errors
UR_
Post by UR_ » Sat Mar 21, 2020 6:53 am
Since updating to this revision
2020-03-20 15:16:04 (rev 21)
libtiff {4.1.0 (conda-forge/win-64) -> 4.1.0 (conda-forge/win-64)}
vtk {8.2.0 (conda-forge/win-64) -> 8.2.0 (conda-forge/win-64)}
(freecad) C:\Users\aio\Miniconda3>conda list vtk
# packages in environment at C:\Users\aio\Miniconda3\envs\freecad:
# Name Version Build Channel
vtk 8.2.0 py38hb4a5736_210 conda-forge
(freecad) C:\Users\aio\Miniconda3>conda list libtiff
libtiff 4.1.0 h885aae3_6 conda-forge
I get these nasty paths:
3>------ Build started: Project: Fem, Configuration: Release x64 ------
3>LINK : fatal error LNK1181: cannot open input file 'D:\bld\vtk_1584655998548\_h_env\Library\lib\liblz4.lib'
3>Done building project "Fem.vcxproj" -- FAILED.
4>------ Build started: Project: FemGui, Configuration: Release x64 ----
4>LINK : fatal error LNK1181: cannot open input file 'D:\bld\vtk_1584655998548\_h_env\Library\lib\liblz4.lib'
4>Done building project "FemGui.vcxproj" -- FAILED.
Looks like some hardcoded paths are left.
How to get rid of them?
looo
Re: conda build 0.19.20188 with linker errors
Post by looo » Sat Mar 21, 2020 8:10 am
reproduced: https://dev.azure.com/sppedflyer/feedst ... 9d50bbeacd
issue: https://github.com/conda-forge/vtk-feedstock/issues/106
Looking at the raw package it seems like a lot of such paths are not correctly replaced. So I guess this is a conda-build problem.
build 210: conda-build 3.19.1
build 209: conda-build 3.19.0
https://github.com/conda/conda-build/issues/3909
edit: best to pin older version of vtk until a new vtk-package with a fixed conda-build is available. The last freecad-build available from freecad/label/dev used vtk_8.2.0-py38h4a1a8eb_208
conda install vtk=*=*_208
looo
Post by looo » Mon Apr 06, 2020 4:02 pm
updating vtk to latest version should be fine again. The path-replacement somehow was not working but is now working thanks to @seanyen:
https://github.com/conda-forge/ripgrep- ... ck/pull/12
Who is online
Users browsing this forum: No registered users and 5 guests
