I hate to show up only when something breaks. Please know that I sincerely thank you all for this great program software. It truly is good enough I'm sure I couldn't afford it.
About twice a year something changes in Gentoo and completely breaks a dependency, or half a dozen. This was today after a large QT update.
I'm using latest git code and getting this error. Not sure what I have going wrong, need a direction to look in.
[ 3%] Copying /home/cory/sources/freecad-code/src/Mod/Material/Templatematerial.yml to /home/cory/freecad2/Mod/Material/Templatematerial.yml
[ 3%] Generating Material_rc.py
PySide2 resource compiler
/usr/bin/pyside2-rcc: Unknown option: '--generator=python'
Usage: /usr/bin/pyside2-rcc [options] <inputs>
Options:
-o file Write output to file rather than stdout
-py2 Generate code for any Python v2.x version
-py3 Generate code for any Python v3.x version (default)
-name name Create an external initialization function with name
-threshold level Threshold to consider compressing files
-compress level Compress input files by level
-root path Prefix resource access path with root path
-no-compress Disable all compression
-version Display version
-help Display this information
make[2]: *** [src/Mod/Material/CMakeFiles/Material.dir/build.make:90: src/Mod/Material/Material_rc.py] Error 1
make[1]: *** [CMakeFiles/Makefile2:3127: src/Mod/Material/CMakeFiles/Material.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
Thanks
Cory
