Trouble compiling FreeCAD on an ARM64 SD845 device
EnigmaVoidX
Re: FreeCAD and Raspberry Pi 4
Post by EnigmaVoidX » Wed Apr 08, 2020 8:36 pm
-alex- wrote:
Wed Apr 08, 2020 4:30 pm
EnigmaVoidX wrote:
Wed Apr 08, 2020 6:31 am
-alex- wrote:
Fri Apr 03, 2020 2:29 pm
EnigmaVoidX wrote:
Wed Apr 01, 2020 7:35 pm
I dont own an rpi4, but I am trying to run it on a arm64 device .... I can easily build using python3 but when it comes to launching it I get segfaults. I dont know if its python 3 or the fact I'm using a software 3d accelerator (llvmpipe)?
Any input?
Hi, I don't know about ARM64 device, however following previous investigations the segfault issue seems due to Coin3D-QT5.
So you can try to compile PY3/Qt4 https://forum.freecadweb.org/viewtopic. ... 80#p340741
I followed your commands and now I get an error that says:
QWidget::Repaint: Recursive repaint detected.
Could you give us the QT version installed? And thank you to past the output error by using the code tag tool in you message.
Kunda1 wrote:ping
Please Kunda could you maybe splite the last 6 messages from EnigmaVoidX and my replies in a new thread titeld" Trouble to compile FreeCAD on an ARM64 SD845 device"? Because that does not concerne directly Raspberry PI4 device.
I have Qt4 installed on my system. I dont know what it is, if I build using python2.7 and qt4 I get a segfault segsev error. However following your linked post if I build using Python3 and qt4 it gives the Qwidget::Repaint: Recursive Repaint Detected.
I dont know if there is some permission error I am not seeing? Because I do my software 3D acceleration via llvmpipe and I can run both blender and gmsh which use openGL.
EnigmaVoidX
Re: Trouble compiling FreeCAD on an ARM64 SD845 device
Post by EnigmaVoidX » Wed Apr 08, 2020 8:39 pm
Kunda1 wrote:
Wed Apr 08, 2020 8:30 pm
Kunda1 wrote:ping
Done ;)
Actually Kunda, I did have a different post here which pointed me to the rpi4 thread (link:https://forum.freecadweb.org/viewtopic. ... 3&start=20) is it worth merging it here to keep forum clean? I dont want it to be considered spam.
Appreciate it.
sgrogan
Post by sgrogan » Wed Apr 08, 2020 8:44 pm
Not spam the topic has just shifted focus.
You can launch "FreeCAD -l" you will get a log file in .FreeCAD directory.
In addition to QT4 can you determine the OpenGL and Gmesh versions? With QT4 maybe the OpenGL version is a wild goose chase, but with QT5 the version matters.
"fight the good fight"
EnigmaVoidX
Post by EnigmaVoidX » Wed Apr 08, 2020 9:47 pm
That sounds good!
So for your information:
-OpenGL version: 3.1 MESA 19.2.8
-GMSH Version: 3.0.6
-QT Version: 4.8.7
FREECAD log:
Msg: FreeCAD 0.18, Libs: 0.18RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Time = Wed Apr  8 21:33:44 2020
Log: AppDataSkipVendor = true
Log: AppHomePath = /home/andrutu/Downloads/freecad-build/
Log: AppIcon = freecad
Log: AppTempPath = /tmp/
Log: BinPath = /home/andrutu/Downloads/freecad-build/bin/
Log: BuildRepositoryURL = Unknown
Log: BuildRevision = Unknown
Log: BuildRevisionDate = Unknown
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Debug = 1
Log: DocPath = /home/andrutu/Downloads/freecad-build/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18
Log: LoggingFile = 1
Log: LoggingFileName = /home/andrutu/.FreeCAD/FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
Log: PYTHONPATH =
Log: PythonSearchPath = /usr/lib/python36.zip:/usr/lib/python3.6:/usr/lib/python3.6:/usr/lib/python3.6/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /home/andrutu/.FreeCAD/system.cfg
Log: UserAppData = /home/andrutu/.FreeCAD/
Log: UserHomePath = /home/andrutu
Log: UserParameter = /home/andrutu/.FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init:   Searching for modules...
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Points... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Test... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Image... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Mesh... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Part... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/PartDesign... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Raytracing... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Drawing... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Sketcher... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Robot... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/ReverseEngineering... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/MeshPart... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Draft... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Web... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Surface... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Start... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Import... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Inspection... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Fem... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Spreadsheet... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Path... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Measure... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/TechDraw... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Complete... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Material... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Idf... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Arch... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Ship(Init.py not found)... ignore
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/OpenSCAD... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Plot(Init.py not found)... ignore
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Show(Init.py not found)... ignore
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/AddonManager... done
Log: Init:      Initializing /home/andrutu/Downloads/freecad-build/Mod/Tux(Init.py not found)... ignore
Log: Using /home/andrutu/Downloads/freecad-build/Mod as module path!
Log: System path after init:
Log:    /home/andrutu/Downloads/freecad-build/bin
Log:    /home/andrutu/Downloads/freecad-build/Mod/Points
Log:    /home/andrutu/Downloads/freecad-build/Mod/Test
Log:    /home/andrutu/Downloads/freecad-build/Mod/Image
Log:    /home/andrutu/Downloads/freecad-build/Mod/Mesh
Log:    /home/andrutu/Downloads/freecad-build/Mod/Part
Log:    /home/andrutu/Downloads/freecad-build/Mod/PartDesign
Log:    /home/andrutu/Downloads/freecad-build/Mod/Raytracing
Log:    /home/andrutu/Downloads/freecad-build/Mod/Drawing
Log:    /home/andrutu/Downloads/freecad-build/Mod/Sketcher
Log:    /home/andrutu/Downloads/freecad-build/Mod/Robot
Log:    /home/andrutu/Downloads/freecad-build/Mod/ReverseEngineering
Log:    /home/andrutu/Downloads/freecad-build/Mod/MeshPart
Log:    /home/andrutu/Downloads/freecad-build/Mod/Draft
Log:    /home/andrutu/Downloads/freecad-build/Mod/Web
Log:    /home/andrutu/Downloads/freecad-build/Mod/Surface
Log:    /home/andrutu/Downloads/freecad-build/Mod/Start
Log:    /home/andrutu/Downloads/freecad-build/Mod/Import
Log:    /home/andrutu/Downloads/freecad-build/Mod/Inspection
Log:    /home/andrutu/Downloads/freecad-build/Mod/Fem
Log:    /home/andrutu/Downloads/freecad-build/Mod/Spreadsheet
Log:    /home/andrutu/Downloads/freecad-build/Mod/Path
Log:    /home/andrutu/Downloads/freecad-build/Mod/Measure
Log:    /home/andrutu/Downloads/freecad-build/Mod/TechDraw
Log:    /home/andrutu/Downloads/freecad-build/Mod/Complete
Log:    /home/andrutu/Downloads/freecad-build/Mod/Material
Log:    /home/andrutu/Downloads/freecad-build/Mod/Idf
Log:    /home/andrutu/Downloads/freecad-build/Mod/Arch
Log:    /home/andrutu/Downloads/freecad-build/Mod/Ship
Log:    /home/andrutu/Downloads/freecad-build/Mod/OpenSCAD
Log:    /home/andrutu/Downloads/freecad-build/Mod/Plot
Log:    /home/andrutu/Downloads/freecad-build/Mod/Show
Log:    /home/andrutu/Downloads/freecad-build/Mod/AddonManager
Log:    /home/andrutu/Downloads/freecad-build/Mod/Tux
Log:    /usr/local/sbin
Log:    /usr/local/bin
Log:    /usr/sbin
Log:    /usr/bin
Log:    /sbin
Log:    /bin
Log:    /usr/games
Log:    /usr/local/games
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version 3.0 or higher is present
Log: Run Gui init script
Wrn: QNativeImage: Unable to attach to shared memory segment.
Err: Program received signal SIGSEGV, Segmentation fault.
Wrn: QWidget::repaint: Recursive repaint detected
sgrogan
Post by sgrogan » Wed Apr 08, 2020 9:53 pm
That sounds good!
This seems the relevant part from the log;
EnigmaVoidX
Post by EnigmaVoidX » Thu Apr 09, 2020 9:01 pm
That sounds good!
Okay, so what does that mean? (I am no linux pro), is QNativeImage not getting proper permission?
Thanks
sgrogan
Post by sgrogan » Thu Apr 09, 2020 9:36 pm
Don't know :( We need one of the QT gurus.
Can you run FreeCAD with gdb? Maybe the stack trace would help?
I'm a Win guy, it just looks like OpenGL and QT aren't playing well together.
EnigmaVoidX
Post by EnigmaVoidX » Fri Apr 10, 2020 1:01 am
I cant run gdb, it will always give me exit code 182.
EnigmaVoidX
Post by EnigmaVoidX » Tue Apr 21, 2020 8:50 am
Alright boys and girls,
Apparently UserLAnd has some errors. i was able to install Fedora 30 into termux proot container, and dnf install freecad (latest release) and it launched fine.
Fingers crossed other functions works!
xf3qc
Post by xf3qc » Mon Sep 07, 2020 10:12 pm
ohmy
no freecad for pine laptop?
this isn't right.
Who is online
Users browsing this forum: No registered users and 2 guests
