Build failure at 32%
foxx00
Post by foxx00 » Tue Sep 01, 2020 12:14 am
[ 32%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeaturePartSpline.cpp.o
[ 32%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeatureChamfer.cpp.o
[ 32%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeatureCompound.cpp.o
[ 32%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeatureExtrusion.cpp.o
In file included from /usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce/TopTools_SequenceOfShape.hxx:112:0,
                 from /usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce/BRepOffsetAPI_ThruSections.hxx:13,
                 from /home/foxx00/Downloads/git/FreeCAD/src/Mod/Part/App/FeatureExtrusion.cpp:34:
/usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce/TCollection_Sequence.lxx: In copy constructor ‘TopTools_SequenceOfShape::TopTools_SequenceOfShape(const TopTools_SequenceOfShape&)’:
/usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce/TCollection_Sequence.lxx:31:8: warning: base class ‘class TCollection_BaseSequence’ should be explicitly initialized in the copy constructor [-Wextra]
 inline TCollection_Sequence::TCollection_Sequence(const TCollection_Sequence& theOther)
[ 32%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeatureFace.cpp.o
[ 32%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeatureFillet.cpp.o
/home/foxx00/Downloads/git/FreeCAD/src/Mod/Part/App/FeatureFillet.cpp: In member function ‘virtual App::DocumentObjectExecReturn* Part::Fillet::execute()’:
/home/foxx00/Downloads/git/FreeCAD/src/Mod/Part/App/FeatureFillet.cpp:80:31: error: ‘Precision’ has not been declared
         double minTol = 2.0 * Precision::Confusion();
/home/foxx00/Downloads/git/FreeCAD/src/Mod/Part/App/FeatureFillet.cpp:81:31: error: ‘Precision’ has not been declared
         double maxTol = 4.0 * Precision::Confusion();
/home/foxx00/Downloads/git/FreeCAD/src/Mod/Part/App/FeatureFillet.cpp:82:27: error: ‘Precision’ has not been declared
         bool rc = ts->fix(Precision::Confusion(), minTol, maxTol);
src/Mod/Part/App/CMakeFiles/Part.dir/build.make:922: recipe for target 'src/Mod/Part/App/CMakeFiles/Part.dir/FeatureFillet.cpp.o' failed
make[2]: *** [src/Mod/Part/App/CMakeFiles/Part.dir/FeatureFillet.cpp.o] Error 1
CMakeFiles/Makefile2:1958: recipe for target 'src/Mod/Part/App/CMakeFiles/Part.dir/all' failed
make[1]: *** [src/Mod/Part/App/CMakeFiles/Part.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
Thanks for the suggestions all :)
Re: Build failure at 32%
Post by chrisb » Tue Sep 01, 2020 4:00 am
Hi and welcome.
Please edit your post and put the output in codetags (button </>) for improved readability. It would probably be helpful if you add at least which OS you use.
Site Admin
Post by wmayer » Tue Sep 01, 2020 5:48 am
In FeatureFillet.cpp you have to add this line in the top area of the file:
#include <Precision.hxx>
It might be not the only file that fails because of that.
According to the directory /home/foxx00/Downloads/git/ you may have cloned the repository via git. So, it's easy to create a patch or even a PR later to merge the changes upstream.
vocx
Post by vocx » Tue Sep 01, 2020 4:32 pm
You are using the community version (OCE) of OpenCASCADE, instead of the official version (OCCT).
Use the official version as the community edition hasn't been updated in years.
Who is online
Users browsing this forum: cliff314159 and 4 guests
