Various builds with one issue or another (prob my setup)
pipe2null
Post by pipe2null » Mon Sep 07, 2020 3:57 am
I am having a heck of a time getting an install going that both works with my spacemouse *AND* has functional FEM. I would much prefer to get a build working correctly from the repo than doing a workaround on an Appimage. I have been over the build prereq's many times and I'm pretty sure I have them all, and I build and install clean, but I'm getting errors when app trying to load Calculix results during FEM, which could mean I have a problem with my environment/missed prereq, etc, but I don't know. At this point I've tried everything I could think of, so I am open for suggestions.
I have tried:
* FreeCAD_0.19-22284-Linux-Conda_glibc2.12-x86_64.AppImage
- This crashes for me on window launch, the initial splash screen shows loading, but crashes shortly after.
*FreeCAD_0.18-16146-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
-This is stable for me and generally works well, including FEM, but there appears to be some mismatch in SpaceNav libraries compared to my OS or something like that and this version of Freecad does not detect my spacemouse. Note, my spacemouse works as expected with OpenSCAD, Blender, and a built from source FreeCAD, which is next on this list.
*Built from source based on master branch:
- With some minor usage so far, this appears stable and works well with my spacemouse, but I consistently get a FEM error when attempting to load results after Calculix finishes, more on this issue below.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.22366 (Git)
Build type: Unknown
Hash: 34c11fcc63efa2fc72cbc74c75c76e9f19d5c84c
Python version: 3.6.9
Qt version: 5.9.5
Report view debug spew:
19:19:31 References: empty in MaterialSolid, MaterialSolid
19:19:31 References: Face in ConstraintFixed, ConstraintFixed
19:19:31 References: Face in ConstraintForce, ConstraintForce
19:19:31 References: Face in ConstraintForce001, ConstraintForce001
19:19:31 Check prerequisites.
19:19:31 Start writing CalculiX input file
19:19:31 Write ccx input file to: /home/blah/_TMP/PrototypeFrame/SolverCcxTools/FEMMeshGmsh.inp
19:19:31 ConstraintFixed:
19:19:31 Type: Fem::ConstraintFixed, Name: ConstraintFixed
19:19:31 ReferenceShape ... Type: Face, Object name: Pad, Object label: Pad, Element name: Face16
19:19:31 ReferenceShape ... Type: Face, Object name: Pad, Object label: Pad, Element name: Face9
19:19:31 ConstraintForce:
19:19:31 Type: Fem::ConstraintForce, Name: ConstraintForce
19:19:31 ReferenceShape ... Type: Face, Object name: Pad, Object label: Pad, Element name: Face5
19:19:31 ReferenceShape ... Type: Face, Object name: Pad, Object label: Pad, Element name: Face4
19:19:31 ConstraintForce001:
19:19:31 Type: Fem::ConstraintForce, Name: ConstraintForce001
19:19:31 ReferenceShape ... Type: Face, Object name: Pad, Object label: Pad, Element name: Face18
19:19:31 Writing time CalculiX input file: 5.61 seconds
19:19:33 run CalculiX at: /usr/bin/ccx with: /home/blah/_TMP/PrototypeFrame/SolverCcxTools/FEMMeshGmsh.inp
19:19:37 CalculiX done without error!
19:19:37 We will load the ccx frd and dat result file.
19:19:37 Read ccx results from frd file: /home/blah/_TMP/PrototypeFrame/SolverCcxTools/FEMMeshGmsh.frd
19:19:37 loading results failed
Files in analysis:
SolverCcxTools.zip
(226.91 KiB) Downloaded 5 times
If you have any suggestions on things to try, I'd appreciate it.
Who is online
Users browsing this forum: No registered users and 3 guests
