MacOS 11 - v0.18 crashes on Right-Click / v0.19 doesn't even load
Sunoo
Post by Sunoo » Sat Sep 19, 2020 3:27 am
There was some back and forth on this on Twitter, before I was asked to post here: https://twitter.com/FreeCADNews/status/ ... 3074302977
The short version is that version 0.18 crashes immediately when right-clicking 100% of the time, and 0.19 just never launches at all. See the tweet thread for screenshots.
Reason: Updated thread title for more clarity
Re: MacOS 11 - v0.18 crashes on Right-Click / v0.19 doesn't even load
Post by Kunda1 » Sat Sep 19, 2020 3:46 am
Thanks for posting!
Could you paste your About info for 0.18 at least since you can load the GUI
Post by chrisb » Sat Sep 19, 2020 5:05 am
Can you start from commandline when starting 0.19 and post the output here?
Post by Kunda1 » Sat Sep 19, 2020 9:30 am
The Twitter feed shows this produces nothing. It outputs the normal ascii FreeCAD message and then just hangs
Edit:
https://mobile.twitter.com/sunookitsune ... 0339727365
looo
Post by looo » Sat Sep 19, 2020 1:14 pm
I guess this something related to the new version 11. There were already some issues reported for the current qt-build used with newer osx versions (10.15).
If I were dependent on a mac system I would:
1. try to install freecad via conda and see if it works, if not
2. try a minimal qt app and see if it works, if not
3. create an issue for conda-forge/qt-feedstock and ask @mingwandroid for help
I guess building qt and freecad (and eventually other deps of freecad) with a newer sdk version will solve such problems. At least there were some errors reported due to sdk mismatch.
Sunoo
Post by Sunoo » Sat Sep 19, 2020 3:51 pm
Thanks for posting!
Here you go:
OS: macOS 10.16
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
And if it helps, here is the dump macOS displays after the crash: https://pastebin.com/D7AgWYqc
Zolko
Post by Zolko » Mon Sep 21, 2020 9:36 am
OS: macOS 10.16
Don't use anything after and including 10.15, it's crap, complain at Apple, THEY are responsible for it. THEY are crippling YOUR OS on purpose, and at the same time claiming how the greatest they are. You believed the hype, now live with it. Since the death of Steve Jobs they have lost the plot, there is nothing to be saved their anymore, they are only in the business to make hundreds of billions through tax evasion.
sudo softwareupdate --ignore "macOS Catalina"
Sunoo
Post by Sunoo » Mon Sep 21, 2020 1:37 pm
Thanks for providing your completely useless opinion about macOS, it really helps get to the bottom of the issue with FreeCAD.
leonard shelby
Post by leonard shelby » Mon Sep 21, 2020 3:17 pm
I also have mac os 11 and the last two 0.19 nightly builds are not working anymore. That said,
Version: 0.19.22358 (Git) is the last version that works like a charm.
It has to be some change since that git release that broke freeCAD on mac. I'm afraid I have no idea how to help find it. Other qt apps are working fine here as well.
looo
Post by looo » Mon Sep 21, 2020 3:48 pm
possible qt update (qt5.12.5 -> qt5.12.9).
can you start the last working version and see which qt-version was in use. You can also check the versions by starting FreeCAD via command line. versions are printed in the terminal.
Who is online
Users browsing this forum: No registered users and 5 guests
