3Dconnexion mouse
freecad-heini-1
Re: 3Dconnexion mouse
Post by freecad-heini-1 » Fri Jun 17, 2016 4:52 pm
/etc/init.d/spacenavd start
[ ok ] Starting spacenavd (via systemctl): spacenavd.service.
tail -n100 -f /var/log/spnavd.log
Spacenav daemon 0.6
failed to open config file /etc/spnavrc: No such file or directory. using defaults.
Device detection, parsing /proc/bus/input/devices
found usb device [46d:c626]: "3Dconnexion SpaceNavigator" (/dev/input/event12)
adding device.
device name: 3Dconnexion SpaceNavigator
Number of axes: 6
Axis 0 value range: -500 - 500 (fuzz: 0)
Axis 1 value range: -500 - 500 (fuzz: 0)
Axis 2 value range: -500 - 500 (fuzz: 0)
Axis 3 value range: -500 - 500 (fuzz: 0)
Axis 4 value range: -500 - 500 (fuzz: 0)
Axis 5 value range: -500 - 500 (fuzz: 0)
using device: /dev/input/event12
trying to open X11 display ":0.0"
XAUTHORITY=/home/wrenkel/.Xauthority
handle_hotplug called
already using device: 3Dconnexion SpaceNavigator (/dev/input/event12)
failed to find any supported devices
adding dev event for device: /dev/input/event12
Lost the X server!
waiting for the X socket file to appear
Ups, something is going wrong ...
I will try this:
sudo xhost +
access control disabled, clients can connect from any host
sudo /etc/init.d/spacenavd restart
[ ok ] Restarting spacenavd (via systemctl): spacenavd.service.
Spacenav daemon 0.6
adding device.
  Number of axes: 6
Lost the X server!
Any idea what goes wrong here?
freecad-heini-1
Post by freecad-heini-1 » Fri Jun 17, 2016 5:02 pm
I installed the latest libgtkmm, but still no success:
sudo /etc/init.d/spacenavd start
Spacenav daemon 0.6
adding device.
  Number of axes: 6
[color=#FF0000]failed to find any supported devices[/color]
What's the problem?
tanderson69
Post by tanderson69 » Fri Jun 17, 2016 6:27 pm
freecad-heini-1 wrote:What's the problem?
Not sure.
you compiled freecad yourself? if so, did you have libspnav installed? A quick check:
ldd freecad
you should see something like:
libspnav.so.0 => /usr/lib/libspnav.so.0 (0x00007f410788f000)
from your log file:
Lost the X server!
Been a long time since I ran the spacenav driver, so I don't know if this is significant or not.
freecad-heini-1
Post by freecad-heini-1 » Fri Jun 17, 2016 7:30 pm
Not sure.
No it's standard installation on Xubuntu 16.04.
tanderson69 wrote: if so, did you have libspnav installed?
No, it's not installed. If I try to install with sudo apt-get install libspnav, message is "cannot find libspnav.
tanderson69 wrote:A quick check:
ldd freecad
There is no directory called .freecad, because it's a standard installation, not self compiled.
tanderson69 wrote:you should see something like:
There is no package named libspnav
tanderson69 wrote:from your log file:
Lost the X server!
Sorry, difficult to understand for me, because it's not compiled and libspnav, I don't know this library.
I have installed spacenavd from repo:
http://www.freecadweb.org/wiki/index.ph ... ut_devices
sudo apt-get install spacenavd
tanderson69
Post by tanderson69 » Fri Jun 17, 2016 8:24 pm
freecad-heini-1 wrote:No it's standard installation on Xubuntu 16.04.
Ok. The repository version has been linked with libspnav:
apt-cache showpkg freecad
Package: freecad
Versions:
0.15.4671+dfsg1-4 (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-amd64_Packages)
 Description Language:
                 File: /var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-amd64_Packages
                  MD5: 55d1732b8e97faf08259c4148b4e3f24
                 File: /var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-i386_Packages
 Description Language: en
                 File: /var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_xenial_universe_i18n_Translation-en
Reverse Depends:
  freecad-dev,freecad 0.15.4671+dfsg1-4
  freecad:i386,freecad
  science-engineering,freecad
  freecad-doc,freecad 0.15.4671+dfsg1-4
Dependencies:
0.15.4671+dfsg1-4 - libsoqt4-20 (2 1.6) python-collada (0 (null)) python-matplotlib (0 (null)) python-pivy (2 0.5.0~v609hg-2) python-ply (0 (null)) python-pyside (0 (null)) pyside-tools (0 (null)) python:any (2 2.6.6-7~) python2.7 (0 (null)) libboost-program-options1.58.0 (0 (null)) libboost-regex1.58.0 (0 (null)) libboost-signals1.58.0 (0 (null)) libboost-system1.58.0 (0 (null)) libc6 (2 2.14) libcoin80v5 (0 (null)) libfreetype6 (2 2.2.1) libgcc1 (2 1:3.4) libgl1-mesa-glx (16 (null)) libgl1 (0 (null)) libglu1-mesa (16 (null)) libglu1 (0 (null)) liboce-foundation10 (0 (null)) liboce-modeling10 (0 (null)) liboce-ocaf-lite10 (0 (null)) liboce-ocaf10 (0 (null)) liboce-visualization10 (0 (null)) libpython2.7 (2 2.7) libqt4-network (2 4:4.5.3) libqt4-opengl (2 4:4.6.1) libqt4-svg (2 4:4.5.3) libqt4-xml (2 4:4.5.3) libqtcore4 (2 4:4.8.0) libqtgui4 (2 4:4.8.0) libqtwebkit4 (0 (null)) libshiboken1.2v5 (2 1.1.0) libspnav0 (2 0.2.2) libstdc++6 (2 5.2) libx11-6 (0 (null)) libxerces-c3.1 (0 (null)) libzipios++0v5 (0 (null)) zlib1g (2 1:1.1.4) freecad-doc (0 (null)) freecad:i386 (32 (null))
Provides:
0.15.4671+dfsg1-4 -
Reverse Provides:
freecad-heini-1 wrote:No, it's not installed. If I try to install with sudo apt-get install libspnav, message is "cannot find libspnav.
package is actually libspnav0, but doesn't matter as the repo version is linked.
run freecad from terminal with:
FreeCAD -l
You can shut it down as soon as it is running. This will create a log file in the hidden .FreeCAD folder under your home folder. Inside that log file should be a message describing whether or not it was able to connect to the spacenav daemon. Mine says 'Log: Connected to spacenav daemon'
lukasubo
Post by lukasubo » Sat Jun 18, 2016 2:58 am
The repo version is outdated, but downloading the source and installing it is fairly easy. As I recall, that solved some issues I had.
NormandC
Post by NormandC » Sun Jun 19, 2016 3:39 pm
Package: freecad
Versions:
freecad-heini-1 is not using the Ubuntu repo version, I believe he's using the PPA's. See his first post: viewtopic.php?f=4&t=9198&start=60#p128331
lukasubo wrote:downloading the source and installing it is fairly easy.
That should be unnecessary on Ubuntu with the PPA's.
freecad-heini-1
Post by freecad-heini-1 » Mon Jun 20, 2016 9:44 am
For the 0.17 version I installed this way:
sudo add-apt-repository ppa:freecad-maintainers/freecad-daily
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install freecad freecad-doc
For the 0.16 version I installed this way:
sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
udo apt-get update
Space-Navigator:
sgrogan
Post by sgrogan » Wed Jun 22, 2016 11:08 pm
freecad-heini-1 wrote:For the 0.17 version I installed this way:
sudo apt-get update
Should be
sudo apt-get install freecad-daily freecad-daily-doc
The package name is different to allow 0.16 and 0.17 to coexist.
"fight the good fight"
spikey
Post by spikey » Tue May 16, 2017 12:08 am
Hello Guys,
I already asked ths question before in a new threads in "help on using freecad" and "install/compile" topic.
but besides a recent link to this thread i had no response so far.
my problem.. I purchased a 2e hand space navigator and installed spacenavd 0.6
have it installed in Ubuntu 16.04 / 16.10 and now 17.04
although the setup itself isn't always easy i have always been able to get it to work (using the sudo xhost +, sudo /etc/init.d/spacenavd restart ) before start up. (just did a mod from this page but haven't tested it yet).
anyway the space navigator works.. EXCEPT! the buttons.
the button field is there (not blank) but everything is greyed out.. there is nothing i can do with it. (see prntscn.jpg)
is there something i did do wrong here or didn't do.. so the buttons don't work?
or anyone else has an idea?
would really appreciate any assistance.
any test will be done on request.. i'd give it already if i know what to give and how to give it.
Kind greatz
Matthieu
OS: Ubuntu 17.04
Version: 0.17.11051 (Git)
Build type: None
Hash: 32176dba86db44775be51c5d8514a229fb27111f
Python version: 2.7.13
OCC version: 7.1.0
Screenshot from 2017-05-16 02-02-50.png (27.9 KiB) Viewed 1528 times
Who is online
Users browsing this forum: No registered users and 3 guests
