some references:
pypy: https://www.pypy.org/
PyPy has support for the CPython C API, however there are constructs that are not compatible. We strongly advise use of CFFI instead.
So it doesn't sound like a good idea to try to support pypy. But on the other hand, there are several compiled libraries ported to pypy already like numpy and meshpy.C extensions need to be recompiled for PyPy in order to work. Depending on your build system, it might work out of the box or will be slightly harder.
Anyway if someone is interested here are the relevant PR's:
- pivy
- ifc-openshell
- libredwg
- (libmed)
