YesJoel_graff wrote: ↑Fri Jun 12, 2020 12:49 am Is it still throwing errors when the workbench activates?
Civil engineering feature implementation (Transportation Engineering)
- HakanSeven12
Re: Civil engineering feature implementation (Transportation Engineering)
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
ok. Just checking - have you puled the latest? I updated a couple days ago. I don't see issues on my side, so I don't know what the problem is.
- HakanSeven12
Yes.
During initialization the error "cannot import name 'Const' from 'pivy_trackers' (unknown location)" occurred in freecad.trails
File "<string>", line 148, in InitApplications
File "C:\Users\Hakan\Downloads\FreeCAD_0.19.21125-Win-Conda_vc14.x-x86_64\bin\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\__init__.py", line 52, in <module>
ContextTracker = import_class(
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\__init__.py", line 50, in import_class
return getattr(import_module(path, name), name)
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\__init__.py", line 43, in import_module
return __import__(path, globals(), locals(), _name_list)
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\pivy_trackers\pivy_trackers\tracker\context_tracker.py", line 27, in <module>
from ..trait.base import Base
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\pivy_trackers\pivy_trackers\trait\base.py", line 26, in <module>
from ..coin.coin_enums import NodeTypes as Nodes
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\pivy_trackers\pivy_trackers\coin\coin_enums.py", line 26, in <module>
from pivy_trackers import Const
ImportError: cannot import name 'Const' from 'pivy_trackers' (unknown location)
- HakanSeven12
- Joel_graff
Yeah, this is exactly what I didn't want to do.HakanSeven12 wrote: ↑Fri Jun 19, 2020 1:03 pm fix
https://github.com/joelgraff/pivy_trackers/pull/22
've already fixed it on my side, but the github isn't updating correctly. You shouldn't have had to fix anything.
I may end up dumping submodules altogether if I can't get this working reliably here soon. I'll let you know.
- Joel_graff
Ok, so I think I've fixed the issues with this. Pull from freecad.trails/dev and give it a try. We'll get it sorted, but I need to make sure I'm doing it right.
- HakanSeven12
It works.
How must I set the column-filters for importing file with xyz-coordinates alone?
How can I avoid scaling from m to mm? (I am using FC-default coordinates)
Example file (Stanford-bunny) from here:
https://wiki.freecadweb.org/Points_Import
- HakanSeven12
You can use this thread for usage help: https://forum.freecadweb.org/viewtopic.php?f=8&t=34371thschrader wrote: ↑Wed Jun 24, 2020 1:57 pm How must I set the column-filters for importing file with xyz-coordinates alone?
I fixed point file import bug. Update workbech first.
Set columns like that.
Easting = X
Norting = Y
Elevation = Z
- setcolumn.png (29.37 KiB) Viewed 1247 times
Works!HakanSeven12 wrote: ↑Wed Jun 24, 2020 2:33 pm ...
Easting = X
Norting = Y
Elevation = Z
