node editor - pyflow
Re: node editor - pyflow
Hello everyone,
I did some experiments with PyFlow Nodes with FreeCAD.
With new nodes using Python lists and made nodes for GIS2BIM in PyFlow based on Python Functions.
GIS2BIM is a collection of nodes I made for Dynamo a couple of years ago:
https://github.com/DutchSailor/GIS2BIM
The quality of the Pythoncode is unfortunately not on the level as you guys do it, I'm trying my best to reach your standard.
• Additional nodes: https://github.com/DutchSailor/FOSS-BIM ... /PyFactory
• GIS2BIM-nodes: https://github.com/DutchSailor/FOSS-BIM ... m/GIStoBIM
• Example PyFlowgraph: https://github.com/DutchSailor/FOSS-BIM ... %20GIS2Bim
Some problems:
• Couldn’t get the FreeCAD-nodes working in Pyflow.
• PythonNode within PyFlow is not working so I made the nodes editing the functionlibraries python file.
• Couldn't figure out how to make your own 'pinType' so a list is now a 'anyPin' type.
Some questions:
• I think that PyFlow can work for FreeCAD like Dynamo for Revit. A lot of users without coding experience can use it for automation. What is your vision on this?
• What do you think of using Python lists within Pyflow versus Numpy Arrays?
Please feel free to make any comments or if you think things should go in another direction.
Some problems:
Some questions:
Sorry for noob question
Could you add nodes for connect LibreOffice Calc and FreeCAD Spread Sheets?
- victor_calixto
Hi guys,
I am getting a error while I try to run "Create All Nodes for Test". Any ideas? It seems to be something related to 'FreeCAD_Toy3'.
My configuration:
OS: Arch Linux
Version: 0.19.23578 (Git) AppImage
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Many thanks,
Cheers.
FreeCAD 0.19, Libs: 0.19R23578 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
---------get FreeCADPyFlow------------------- getInstance @ .../home/klixto/.FreeCAD/Mod/NodeEditor/nodeeditor/pfwrap.py li: 46
<module> @ ...AD/Mod/NodeEditor/PyFlowPackages/PyFlowFreeCAD/Nodes/FreeCAD_Base.py li: 7
<module> @ .../Mod/NodeEditor/PyFlowPackages/PyFlowFreeCAD/Nodes/FreeCAD_Lambda.py li: 7
<module> @ ...D/Mod/NodeEditor/PyFlowPackages/PyFlowFreeCAD/Nodes/FreeCAD_Logic.py li: 8
<nodeeditor.freecad_pyflowapp.FreeCADPyFlow(0x5615fd02a710) at 0x7f92f47090c0>
create instance getInstance @ .../home/klixto/.FreeCAD/Mod/NodeEditor/nodeeditor/pfwrap.py li: 72
A3 available
Unknown command 'ZebraTool'
Unknown command 'GeomInfo'
<nodeeditor.freecad_pyflowapp.FreeCADPyFlow(0x5616001e3310) at 0x7f92b2303b00>
-----------; 0; FreeCAD_ShapePattern
tried to run nodeeditor.dev_all.Coin.run_FreeCAD_ShapePattern(self)
-----------; 1; FreeCAD_Dragger
-----------; 2; FreeCAD_QuadMesh
-----------; 3; FreeCAD_Camera
SoOrthographicCamera
Position; 0.0 0.0 -0.0
tried to run nodeeditor.dev_all.Coin.run_FreeCAD_Camera(self)
-----------; 4; FreeCAD_Boolean
-----------; 5; FreeCAD_Compound
-----------; 6; FreeCAD_Loft
no data on pin; shapes
PyFlowFreeCAD.Nodes.FreeCAD_Combination.FreeCAD_Loft
FreeCAD_Loft
no shapes
-----------; 7; FreeCAD_RepeatPattern
-----------; 8; FreeCAD_Seam
PyFlowFreeCAD.Nodes.FreeCAD_Combination.FreeCAD_Seam
FreeCAD_Seam
no ShapeA
FreeCAD_Seam
no ShapeA
FreeCAD_Seam
no ShapeA
-----------; 9; FreeCAD_Slice
-----------; 10; FreeCAD_Sweep
-----------; 11; FreeCAD_ApplyPlacements
-----------; 12; FreeCAD_Reduce
-----------; 13; FreeCAD_FlipSwapArray
flipswap
shape; (0,)
flipswap
shape; (0,)
flipswap
shape; (0,)
-----------; 14; FreeCAD_IndexToList
-----------; 15; FreeCAD_ListOfPlacements
-----------; 16; FreeCAD_ListOfShapes
-----------; 17; FreeCAD_Transformation
tried to run nodeeditor.dev_all.Conversion.run_FreeCAD_Transformation(self)
-----------; 18; FreeCAD_Zip
-----------; 19; FreeCAD_xyz2uv
-----------; 20; FreeCAD_uv2xyz
-----------; 21; FreeCAD_ListOfVectors
-----------; 22; FreeCAD_ListOfVectorlist
-----------; 23; FreeCAD_MoveVectors
-----------; 24; FreeCAD_ScaleVectors
-----------; 25; FreeCAD_Toy3
Running the Python command 'Micro_createAllNodesforTests' failed:
File "<string>", line 199, in Activated
File "/home/klixto/.FreeCAD/Mod/NodeEditor/nodeeditor/Commands.py", line 1276, in createAllNodesforTests
node=pfwrap.createNode('PyFlowFreeCAD',name,name)
File "/home/klixto/.FreeCAD/Mod/NodeEditor/nodeeditor/pfwrap.py", line 98, in createNode
node = classNodes[nodeClass](nodeName,**kvargs)
('FreeCAD_Toy3',)
OS: Arch Linux
Qt version: 5.12.5
OCC version: 7.4.0
Many thanks,
Cheers.
how can I start using Pyflow WB por nodeditor?
Shoould i just download and copy to MOD folder in windows 10?
I installed it according to your README.md but I have some errors
16:25:06 Traceback (most recent call last):
16:25:06 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\NodeEditor\nodeeditor\freecad_pyflowapp.py", line 240, in closeEvent
16:25:06 self.canvasWidget.shoutDown()
16:25:06 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\PyFlow\PyFlow\UI\Widgets\BlueprintCanvas.py", line 1787, in shoutDown
16:25:06 self.canvas.shoutDown()
16:25:06 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\PyFlow\PyFlow\UI\Widgets\BlueprintCanvas.py", line 343, in shoutDown
16:25:06 node.shoutDown()
16:25:06 AttributeError: 'NoneType' object has no attribute 'shoutDown'
should I install more dependencies?
OS: Windows 10 (10.0)
Version: 0.19.23323 (Git)
Hash: 512d5c6141aec52b6eecc67370336a28fde862a6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Spanish/Peru (es_PE)
20:36:44 Traceback (most recent call last):
20:36:44 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\PyFlow\PyFlow\UI\Widgets\BlueprintCanvas.py", line 1134, in mouseMoveEvent
20:36:44 self.clearSelection()
20:36:44 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\PyFlow\PyFlow\UI\Widgets\BlueprintCanvas.py", line 411, in clearSelection
20:36:44 for node in self.selectedNodes():
20:36:44 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\PyFlow\PyFlow\UI\Widgets\BlueprintCanvas.py", line 404, in selectedNodes
20:36:44 assert(None not in allNodes), "Bad nodes!"
20:36:44 AssertionError: Bad nodes!
20:36:51 selected Nodes ...
20:36:51 Traceback (most recent call last):
20:36:51 File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\NodeEditor\PyFlowPackages\PyFlowFreeCAD\Tools\ComputeTool.py", line 60, in do
20:36:51 if n.getWrapper().isSelected():
20:36:51 AttributeError: 'NoneType' object has no attribute 'isSelected'
this error message appears when FreeCAD is loading (GIS2BIM):Maarten wrote: ↑Mon Dec 28, 2020 1:32 pm
anyway, thanks for share your awesome work.
Qt version: 5.12.5
OCC version: 7.4.0
Mr. @Mircroelly2 how did you install the MAYA nodes?
I did install all others except Maya node because, according to internet, is python 2.
I hope can any dev can read this:
I need to request to create a fork for PyFlow for FreeCAD because microelly2 is MIA (missing in action) anywhere in their blog, discord group, or youtube.
actually, Pyflow is already usable, just a unique node does not load, Maya because python2, for other nodes, just is need install python modules (dependencies) to be usable, I think any developer could do this.
is very necessary to launch a stable Pyflow version because other devs than wish to create nodes for their software need a stable version for than their users can test.
here just is need a unique change if have time, and is than each node should contain their python modules (dependencies)
As far as I know @microelly2 used a fork of pyflow. There were some attempts to unify pyflow with his fork, but as far as I can remember this never happened.jtm2020hyo wrote: ↑Fri Jan 29, 2021 6:29 am I need to request to create a fork for PyFlow for FreeCAD because microelly2 is MIA (missing in action) anywhere in their blog, discord group, or youtube.
I created a pyflow package for conda some time ago. version 2.0.2. I would like to work adding necessary patches to make pyflow compatible with freecad, and further adding the changes to the main repo.
You can start pyflow within freecad (assuming you have a working pyflow installed) with:
from PyFlow.App import PyFlow
from Qt.QtWidgets import QApplication
instance = PyFlow.instance(software="FreeCAD")
instance.show()
