Opening symbols for Arch doors
It is now possible to create this kind of opening symbols for Arch Windows/Doors:
It works like this:
1) Create a window like before
2) Double-click the window in the tree to open its task panel
3) Select a component that is openable
4) Click an edge that is the rotation axis of the component
5) Press the hinge select button
6) Select an opening mode. So far all work except the two sliding modes
7) Press update and close the task panel
Internally, it's rather simple: Each window component is defined by a set of strings in its WindowParts property. I just extended one of the strings (the "Wires" part) to hold also the hinge edge, and a number for the opening mode. So instead of "Wire0,Wire1", it is saved as "Wire0,Wire1,Edge6,Mode1". So it is rather easy to use in scripts, and will be easy to update the presets.
This is already supported by the section plane, so these symbols will appear on Drawing/TechDraw views, but there are still problems with the "V" lines, they are not cut by the other geometry, so they appear everywhere. There are many other things to do to make them better, such as allowing the user to define styles, et... But better to go step by step and see how it behaves first
It works like this:
Re: Opening symbols for Arch doors
Looking good. Such a standard feature in architecture now made easy in FreeCAD.
Hello, Yorik
Congratulations and Thanks for the work developed.
I've been testing the placement of the opening symbols, and I found a strange error, the arch, which should be visible only in plant, also appears in elevation represented as an arc.
must be some bug, keep up the good work
Renato
Renato
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
ah good catch... I had seen this many times but always forgot to fix it... An arc cannot pass through 3 aligned points, so when the view direction is perpendicular to the axis of an arc, it should be represented as a line instead of an arc. Fixing this now.
I was exactly looking for such an option but I cannot see the "Hinge" and "opening mode" lines it when I double click on the door.
Thanks in advance for any help
Wudli
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Wudli
Your first post welcome to the FreeCAD.
You can download development snapshots of 0.17 that will run without needing to be installed and will not effect
Your 0.16 version. So you can try it out if you like.
But do not expect a file edited in 0.17 to wortk properly in 0.16.
Your FreeCAD version is too old. You are using the last release version but all features after april 2016 are in the development version 0.17.
Got it. I think I will first finish my project (I am under a deadline for a 3 story building) and then download 0.17 and start playing around.
Thanks for the super fast response and for all the work all the people put into this awsome project.
I am looking forward to contribute hopefully soon.
A question rel. to build 0.17.268:
Changing window/opening/ width DOES NOT alter opening size in the wall, only the window object changes.
Whats wrong?
cheers,
Whats wrong?
cheers,
cheers,
