Editable texts in SVG templates
yorik
Site Admin
Re: Editable texts in SVG templates
Post by yorik » Sun Jan 08, 2012 3:16 pm
Hmm interesting... It looks like proper XML rules ask that when you use a prefix, you define it first:
http://www.w3schools.com/xml/xml_namespaces.asp
Indeed inkscape defines its inkscape: prefix, at the beginning of inkscape-generated files, there is:
<svg
   xmlns:dc="http://purl.org/dc/elements/1.1/"
   xmlns:cc="http://creativecommons.org/ns#"
   xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
   xmlns:svg="http://www.w3.org/2000/svg"
   xmlns="http://www.w3.org/2000/svg"
   xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
   xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
So we would just need to add: xmlns:freecad="http://some/url"
I'll setup a page on the wiki on the model of the inkscape page... *EDIT* Ah! the inkscape page doesn't exist :( we can do better...
*EDIT2* Done! the line to insert is:
xmlns:freecad="http://sourceforge.net/apps/mediawiki/free-cad/index.php?title=Svg_Namespace"
triplus
Post by triplus » Sun Jan 08, 2012 4:02 pm
yorikvanhavre wrote:Hmm interesting... It looks like proper XML rules ask that when you use a prefix, you define it first:
<svg
Great and there is one more feature now, before if SVG template was edited in Inkscape and then saved:
- in your SVG templates, add freecad:editable="TextName" attributes to <text> entities, to mark them as editable
This was lost but now it persist if it's saved as Inkscape SVG and not Plain SVG. Without namespace URI this was lost if it was saved as Inkscape SVG too, but now it persists.
yorik
Site Admin
Post by yorik » Sun Jan 08, 2012 4:34 pm
triplus wrote:This was lost but now it persist if it's saved as Inkscape SVG and not Plain SVG. Without namespace URI this was lost if it was saved as Inkscape SVG too, but now it persists.
Great! I hadn't noticed that...
NormandC
Post by NormandC » Sun Jan 08, 2012 6:32 pm
The sodipodi link is dead too. Actually, I don't understand why there are Sodipodi:prefix namespaces in Inkscape documents, that software has been dead for almost 8 years, they should had replaced them by Inkscape:prefix... (Sodipodi was the predecessor to Inkscape)
jriegel
Site Admin
Post by jriegel » Sun Jan 08, 2012 8:25 pm
They keep the sodiposi name-space for back wards compatibility.
Stop whining - start coding!
triplus
Post by triplus » Mon Jan 09, 2012 3:56 pm
normandc wrote:Hi triplus,
How about sharing your template (if you don't mind)? :)
The Drawing Templates wiki page could use some A4 templates! ;)
(and some A and B too for people in North America, but I'm slowly working on it!)
My drawing templates are very specific and because of that i made two more simple/generic/standard ones for other to use in A4 Portrait and A3 Landscape sizes.
This are the rules i followed:
One pixel = one millimeter
Add proper "namespace URI" inside (at the beginning of) <svg> tag:
Add attributes to <text> entities, to mark them as editable:
Insert just before the last </svg> tag
<!-- DrawingContent -->
Important: If u edit drawing template in for example Inkscape save it as Inkscape SVG and not Plain SVG if u want all FreeCAD specific changes to persist!
Remove (rename file) the .zip extension from the SVG file. SVG file is not compressed i just can't upload it as .svg file.
a3_landscape.svg.zip
A3 Landscape Drawing Template
(9.83 KiB) Downloaded 247 times
a4_portrait.svg.zip
A4 Portrait Drawing Template
(9.81 KiB) Downloaded 247 times
triplus
Post by triplus » Thu Jun 27, 2013 2:19 am
I assumed 1px = 1mm rule should be used in this templates but i guess i was wrong the template should use mm by default! It does work but exported .SVG must always be resized in Inkscape for example to get correct output size (print).
viewtopic.php?f=10&t=4182&start=10#p32837
jriegel
Site Admin
Post by jriegel » Thu Jun 27, 2013 5:57 am
I'm not able to open the zip files?
Site Admin
Post by wmayer » Thu Jun 27, 2013 9:04 am
jriegel wrote:I'm not able to open the zip files?
Remove the ".zip" suffix.
jriegel
Site Admin
Post by jriegel » Thu Jun 27, 2013 4:56 pm
Ups :oops:
Locked
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
