Arch MultiMaterials
yorik
Site Admin
Re: Arch MultiMaterials
Post by yorik » Thu May 11, 2017 2:56 am
At the moment they only work for Walls, Panels and Windows.
Indeed they could work for structures too, but then it becomes hard to decide how to make the layers.
About the other issues, thanks for notifying. I'll look into it...
MIngB
Post by MIngB » Sat Jul 01, 2017 6:35 pm
Would it still be possible to access the the Volume or Length of each layer?
MultiMaterials is a pretty neat but also really complicated feature... using it, you may have to take precaution on adjoins with other elements which by itself may also be MultiMaterial.
At the moment I can't figure out how to include MultiMaterial into my designs. I mean each joint for itself may cut and/or join into MultiMaterial layers differently.
Actually, my humble opinion is: a Multimaterial element e.g. wall should become a handle, but each layer should be an own element of the actual type e.g. wall in this case. These than can be merged or cut by adjoining elements as wished. Each operation done to the handle is applied to each layer. But operations on a 'layer Element' apply only to itself.
OS: "NAME=Gentoo"
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.11474 (Git)
Build type: Debug
Branch: (HEAD detached at 74e794002)
Hash: 74e794002464b5230966bae86ce84409b0ee74fc
Python version: 2.7.12
Coin version: 3.1.3
OCC version: 7.1.0
yorik
Site Admin
Post by yorik » Tue Jul 04, 2017 3:17 pm
Each layer is still obtainable individually (myObject.Shape.Solids). And it is easy to match each solid with its corresponding material layer, so there is no real "problem" with this approach I think. Indeed it will require more automation, like intelligent walls merging, etc. I still don't have a clear path in mind of how to do that, that ś basically the main reason why it still doesn't exist...
Note that the old, manual behaviour still exists: You can make several walls based on the same baseline, with different offsets and thicknesses and materials, and do the merge manually. So that guarantees fine control when the more automatic way will be insufficient.
MIngB
Post by MIngB » Wed Jul 05, 2017 4:35 pm
I like the way multilayered Objects are now created that easy... I'm looking forward to see what comes next.
In case you see during construction that finer control for already build MultiMaterials is needed, It might come handy to be able to convert/copy a MultiMaterial e.g. wall, into several Objects of the same base(line).
yorik
Site Admin
Post by yorik » Wed Jul 05, 2017 10:19 pm
Indeed, very good idea. Adding to my TODO list.
silopolis
Post by silopolis » Sat Aug 12, 2017 11:25 am
Giving MultiMaterials a test this morning with FreeCAD-daily from Zesty PPA on Debian 9/Stretch (SolydK 9 actually), I couldn't have it work with panels.
Creating a wall and selecting the mulimaterial at creation works, creating a wall and adding multimaterial afterward works too, but no way with panels and getting the following error with them:
  File "/usr/lib/freecad-daily/Mod/Arch/ArchPanel.py", line 507, in execute
    base = baseprofile.extrude(n)
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'extrude'
yorik
Site Admin
Post by yorik » Sat Aug 12, 2017 3:40 pm
Argh it was a stupid typo :) Fixed in git commit d5b554d2b
Giuliano1969
Post by Giuliano1969 » Mon Mar 09, 2020 12:19 am
Hi Yorik
I tested today the multilayer wall feature, but it seems that the different color layer are not displayed.
The wall is drawn as a 1 layer only
See attached mp4 screencast (sorry, I took a long time to find the material propriety during the screencast :-) )
https://drive.google.com/open?id=1OlCJp ... eWF33OAPu
Is it the correct behavior ?
BR
Giuliano
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
Locale: Italian/Italy (it_IT)
yorik
Site Admin
Post by yorik » Thu Mar 12, 2020 2:35 pm
There are several regression bugs there, probably introduced by the multiple-width sketches work by @paullee... I fixed one in git commit 1fb999be37 but there are still things not working correctly...
paullee
Post by paullee » Thu Mar 12, 2020 6:55 pm
@Yorik's post bring me here :)
Indeed fusing Sketch-based Wall Segments make layer disappeared.
But I have long noted bugs that want to fix but do not find more time to think how to, see :-
Sep 2017 MultiMaterials + (multiple) ArchWalls on 1 Sketch
Nov 2019 [ Bug ] Multi-material cannot be applied to a sketch-based wall
Screenshot from 2017-09-22 07-01-50.png (156.82 KiB) Viewed 648 times
Test _ Multi-material _ Arch Wall _1.FCStd
(50.14 KiB) Downloaded 24 times
Who is online
Users browsing this forum: No registered users and 3 guests
