New Raytracing Workbench for POV-Ray
bavariaSHAPE
Re: New Raytracing Workbench for POV-Ray
Post by bavariaSHAPE » Sat Aug 29, 2020 6:44 pm
Every action in the "Textures Tab" starts POV-Ray. There is also no preview displayed. Is there a setting to prevent this.
I use the WB without Enviroment. Sometimes the WB with Enviroment freezes or does not pass any data for POV-Ray (*.pov is empty).
OS: Windows 7 SP 1 (6.1) (without internet connection)
Version: 0.19.22284 (Git)
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.6.8
Qt version: 5.12.1
The_Raytracers
Post by The_Raytracers » Sat Aug 29, 2020 9:30 pm
Kunda1 wrote:
Sat Aug 29, 2020 3:21 am
What's your account username ?
The username is "The Raytracers"; Yorik said, spaces and underscores are interchangable, but both doesn't work :/ Maybe you can delete the account and recreate it (with computers this often works :) ).
Qt version: 5.12.1
Thanks a lot for your testing!
Is it a model that you could send me so that I can find the bug easier? You can disable the preview by checking the "Disable Live Preview" checkbox. Starts the whole POV-Ray program with the window, etc.? If yes, it is probably due to the slightly different Windows version of POV-Ray. I will setup a virtual machine with Windows tomorrow and test it.
paullee wrote:
Fri Aug 28, 2020 7:55 pm
Missed this previously ! Awesome WB !
Wonder also if integration with Blender can be done ?
Thanks for your feedback!
An integration of other renderers is technically possible, but a lot of work would be necessary. Our approach from the beginning was to support only one renderer and this one very good. So this would be a huge change, but not impossible. There would be a few big points that have to be done:
  • we have to create an exporter for the Blender renderer
  • some structures like the texture storing have to be changed to enable multiple renderers
First, we want to finish the environment tab and create a tutorial similar to this one to show the advantages of the workbench (editing files isn't necessary anymore, etc.): Tutorial_FreeCAD_POV_ray.
Then maybe we can think more detailed about an integration of more renderers (and I have to talk about that with my partner).
Greetings
The_Raytracers
dcapeletti
Post by dcapeletti » Fri Sep 04, 2020 10:15 pm
Hi, since FreeCAD objects support materials and textures through the Arch texture workbench, I would like to know if this workbench allows exporting such texture already configured in the object. See https://www.youtube.com/watch?v=njp61PWWotE
Thanks
The_Raytracers
Post by The_Raytracers » Sun Sep 06, 2020 3:22 pm
Currently this is not supported, but the HDRI tab is nearly finished and I think, this is an important feature; I will add this soon :)
Unfortunately FreeCAD doesn't work in my VM :/
But POV-Ray works and I think, now I know where the error is with the preview. The Windows version of POV-Ray doesn't support the option (or I didn't find it) to suppress the window opening. What do you think about changing the texture choice from only the name to a prerendered (not rendered live) image of the texture?
I think, there occours a python error if the pov file is empty. Could you send the error message, so we can see, where the error is?
Thanks a lot to all for your testing and feedback!
bavariaSHAPE
Post by bavariaSHAPE » Mon Sep 07, 2020 1:40 pm
The order after pressing the button "Open settings dialog and start export" is always numbered as shown in the screenshot. Rendering without and with texture worked only once. I try to find a pattern of the problem.
dcapeletti
Post by dcapeletti » Sat Sep 12, 2020 11:54 am
Please let us know when you publish it.
On the other hand it would be interesting if in the future you support the material and multi-material properties of FreeCAD since this would facilitate a single configuration without having to do it twice. Greetings
The_Raytracers
Post by The_Raytracers » Thu Sep 24, 2020 5:36 pm
With the numbers you mean the order of opening right?
I not really understand the warning window with /EDIT and /RENDER because by default, they aren't passed to POV-Ray. Can you send your POV-Ray-Workbench-Settings, maybe there is the problem.
bavariaSHAPE
Post by bavariaSHAPE » Fri Sep 25, 2020 9:40 am
Is that what you mean? Yes, thats the number of the order of opening.
In the meantime I have a newer version of FreeCAD 0.19 and it is a bit more stable. The message "/EDIT and /RENDER" no longer appears.
The rendering process is as follows:
1) I start the "Open Settings Dialog..." window. POV-Ray is started at the same time.
2) I close POV-Ray and make my settings in the "Open Settings Dialog..." window. Every time I click on a parameter POV-Ray opens, because I close it again.
3) When I close POV-Ray the preview is updated in the "Open Settings Dialog..." window.
4) With "Start Rendering" the image is rendered with the settings made before.
5) If I start the process often, a second "Open Settings Dialog..." window including POV-Ray appears. When I close POV-Ray, the second "Open Settings Dialog..." window disappears as well. But in the first window I can change my settings. If I have changed the view before (zoom, pan) this phenomenon does not happen.
If I maintain the described procedure, I will achieve my desired results. The POV-Ray WB basically simplifies the process to get a rendered image. Also the assignment of materials to the surfaces of several components is fast and simple.
When I deactivate the option "Export FreeCAD Background" it turns black. Is there a way (except in the POV-Ray file) to generate for example a white background?
I would be happy to hear new features from you.
Petert
Post by Petert » Sat Sep 26, 2020 9:00 pm
I like it very much. Much better then the render addon.
Use it for quick renders while I am designing. I use CadRays for the final result.
https://old.opencascade.com/content/cadrays
I am a refugee from Fusion 360, have been using Fusion for almost 5 years now and after the latest debacle with the licensing stuff I had enough of AutoDesk.
Switched over to FreeCAD and am spreading the word.
The_Raytracers
Post by The_Raytracers » Thu Oct 22, 2020 4:02 pm
Thanks for your positive feedback :)
Ah, good that it works better with a newer version. Your settings are right by the way. I think the problem is, that you opened multiple dialog windows, so I blocked that. The new code is on the repo. In addition, I merged the Environment Tab (still beta). Now you can change the background settings there. You can change the background by using a HDR environment or by changing the colors of the FreeCAD background in the settings. You're right, that this is not optimal :/ For more advanced settings you have to use the *_user.inc file.
If you want to create a transparent background, you have to disable the export of the background/environment in the Environment tab and add the
+UA
option in the workbench settings (after +A +P).
Probably, the preview is annyoing for you, you can disable it by checking the "Disable Live Preview" checkbox, then POV-Ray shouldn't open anymore if you change something. I attached a screenshot. You have to do this also in the Environment tab if you change things there.
Greetings
The_Raytracers
Who is online
Users browsing this forum: No registered users and 2 guests
