New Raytracing Workbench for POV-Ray
The_Raytracers
Re: New Raytracing Workbench for POV-Ray
Post by The_Raytracers » Thu Oct 22, 2020 4:29 pm
The_Raytracers wrote:
Thu Oct 22, 2020 4:02 pm
If you want to create a transparent background, you have to disable the export of the background/environment in the Environment tab and add the
+UA
option in the workbench settings (after +A +P).
I forgot, it can be, that POV-Ray previews the transparent parts as black, but in the resulting image file everything will be right.
bavariaSHAPE
Post by bavariaSHAPE » Thu Oct 22, 2020 6:35 pm
Probably, the preview is annyoing for you, you can disable it by checking the "Disable Live Preview" checkbox, then POV-Ray shouldn't open anymore if you change something. I attached a screenshot. You have to do this also in the Environment tab if you change things there.
Greetings
The_Raytracers
Hallo The_Raytracers,
That was the point: "Disable Live review". Now it works fine. The multiple windows no longer open when I change the textures.
This weekend I will test more.
Thanks
The_Raytracers
Post by The_Raytracers » Sat Oct 24, 2020 5:00 pm
Hm, now it is a bit unpractical to choose the right texture in Windows. What do you think about an improved list of textures like in the screenshot? That would give you at least a foreshadow of the texture.
bavariaSHAPE
Post by bavariaSHAPE » Sat Oct 24, 2020 5:36 pm
That sounds really good. I hope it is not too much effort.
dcapeletti
Post by dcapeletti » Sun Oct 25, 2020 1:13 pm
Hello, I try to do the next rendering of the next project but the next error is thrown. See video https://exode.me/videos/watch/3bf9f1b7- ... 03d92b76a5
10:08:48  PovRay.Activated()
10:08:49  Could not open ini file
10:08:51  Path to *.pov File: /home/dcapeletti/Escritorio/test/Test.pov
1 parent objects found in highest layer
containing totally 12 objects
Your model contains 10 objects which aren't supported (will be represented as mesh).
Perspective Camera
10:08:52  Traceback (most recent call last):
10:08:52    File "/home/dcapeletti/.FreeCAD/Mod/exporttopovray/Dialog.py", line 245, in onOk
10:08:52      self.exporter.initExport(self.renderSettings)
10:08:52    File "/home/dcapeletti/.FreeCAD/Mod/exporttopovray/Exporter.py", line 136, in initExport
10:08:52      self.startExport() #start the export
10:08:52    File "/home/dcapeletti/.FreeCAD/Mod/exporttopovray/Exporter.py", line 160, in startExport
10:08:52      objPovCode += self.createPovCode(obj, True, True, True, True, True, True)
10:08:52    File "/home/dcapeletti/.FreeCAD/Mod/exporttopovray/Exporter.py", line 578, in createPovCode
10:08:52      if not self.isBodySupported(fcObj):
10:08:52    File "/home/dcapeletti/.FreeCAD/Mod/exporttopovray/Exporter.py", line 941, in isBodySupported
10:08:52      if not self.isSketchSupported(sketch):
10:08:52    File "/home/dcapeletti/.FreeCAD/Mod/exporttopovray/Exporter.py", line 998, in isSketchSupported
10:08:52      supportedGeometryTypes = [Part.LineSegment, Part.Circle, Part.Point, Part.ArcOfCircle]
10:08:52  AttributeError: type object 'App.Part' has no attribute 'LineSegment'
OS: Debian GNU/Linux 9 (stretch) (GNOME/default)
Version: 0.19.22756 (Git) AppImage
Hash: ce87f586ee36ffe8ebcdcd3947ced4ab389ae795
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Spanish/Argentina (es_AR)
test.ini
(367 Bytes) Downloaded 7 times
Test.FCStd
(20.78 KiB) Downloaded 11 times
Test.ini
(351 Bytes) Downloaded 8 times
The_Raytracers
Post by The_Raytracers » Sun Oct 25, 2020 5:39 pm
Should be fixed now :) Is on the repo, master branch.
Was an error with importing Part. I don't really know where the difference between
from FreeCAD import Part
and
import Part
is. If someone know, please tell me :)
Greetings
The_Raytracers
Post by The_Raytracers » Wed Oct 28, 2020 4:23 pm
Now it's done, even it was more complicated than I thought :)
It is not on master branch already, because I think, more testing is needed before it is merged to master. If anyone wants to test, you can download it, I would very appreciate any feedback :) In addition I added nearly 100 new textures! Huge thanks also to f-lohmueller.de for this great POV-Ray site, I used a lot of textures from there.
Download:
https://gitlab.com/usbhub/exporttopovra ... Thumbnails
The_Raytracers
Post by The_Raytracers » Sat Nov 07, 2020 8:26 pm
I made the top categories bold to improve the clarity. In addition I fixed a small bug. A screenshot of the new categories is attached.
What do you think?
Greetings
The_Raytracers
Petert
Post by Petert » Sat Nov 07, 2020 9:13 pm
Looks very nice, easy to choose now.
Thank you for all your hard work, it is appreciated.
I am a refugee from Fusion 360, have been using Fusion for almost 5 years now and after the latest debacle with the licensing stuff I had enough of AutoDesk.
Switched over to FreeCAD and am spreading the word.
The_Raytracers
Post by The_Raytracers » Wed Nov 11, 2020 5:07 pm
Thanks, the branch is now merged into master, so the thumbnails are delivered with the standard master version. I also updated the GIF in the opening post, so that everyone can see it there too.
We have now also access to the Wiki, so we hope to get in the Addon Manager soon, so that the installation and updates are easier to do.
Greetings
The_Raytracers
Who is online
Users browsing this forum: No registered users and 1 guest
