EaglePCB importer for FreeCAD
FreeRadical
Re: EaglePCB importer for FreeCAD
Post by FreeRadical » Fri Jan 30, 2015 8:35 pm
Alright, it worked! I can view the bare board. I am using the new version of the IDF files (see atttachment).
Thanks, marmni!
It gave these messages:
The file was created in IDF v3.
could not convert string to float: C2
DeprecationWarning: Use 'TypeId' instead
HeightTestv2.zip
Version 2 of IDF height test
(5.41 KiB) Downloaded 63 times
marmni
Post by marmni » Fri Jan 30, 2015 10:22 pm
Thanks for Your feedback. Still white characters ;). Please check files from attachment.
pcb_new.7z
(3.6 KiB) Downloaded 85 times
FreeRadical
Post by FreeRadical » Sat Jan 31, 2015 1:45 am
The C2 error is fixed. It still has the DeprecationWarnings.
Edimahler
Post by Edimahler » Thu Apr 23, 2020 7:05 pm
It's a long time ago and I'm pretty sure, someone will kill me for this... :?
Anyway: Using FreeCAD 0.18 and the newest version of FreeCAD-PCB from February 2020 (Version_for_FreeCAD_min_0.18_and_Python_min_2.7), installing the plugin according to the PDF in the plugin and after changing the paths in the propertys menu, just nothing happens, when I try to open a KiCAD file using the plugin.
Well, for some seconds there is the error message
Traceback (most recent call last): File line 1, in File "C:\Program Files\FreeCAD 0.18\Mod\PCB\PCBbrd.py", line 70, in open importBRD(filename, wersjaFormatu[0]) File "C:\Program Files\FreeCAD 0.18\Mod\PCB\PCBbrd.py", line 230, in importBRD plytkaPCB = mainPCB(wersjaF0rmatu, filename) Fi
in the bottom of FreeCAD. Is there someone around who can understand this? I don't know any python, so don't understand what could be wrong there...
Thanks a lot for some help and best regards,
Simon
Edimahler
Post by Edimahler » Thu Apr 23, 2020 8:01 pm
Sorry, forgot to mention:
- Windows 10
- KiCAD version 5.1.5 (stable)
- Python version 3.8.1
easyw-fc
Post by easyw-fc » Thu Apr 23, 2020 9:13 pm
- Windows 10
Becuase you are wanting KiCAD and not Eagle, probably you may need to try kicad StepUp WB
Edimahler
Post by Edimahler » Fri Apr 24, 2020 10:34 am
Hi easyw-fc,
Thanks for your answer, the screenshots of your mod already look awesome, will try that. Thanks a lot!
Best regards, Simon
Edimahler
Post by Edimahler » Fri Apr 24, 2020 10:55 am
It worked from beginning with this one, without even have to change paths, giving read/write-rights to files or something similar.
Thank you easyw-fc, really appreciate this!
BR Simon
Who is online
Users browsing this forum: No registered users and 1 guest
