Arch MultiMaterials
Arch MultiMaterials
Post by yorik »
A new feature has landed in Arch: Multi-Materials.
The concept is simple: It is a list of layers with a name, a material and a thickness. It can be attributed to Arch objects instead of their normal Material.
Not all of the Arch objects can do something with it. So far:
- Walls and Panels use it to create multi-layer walls and panels. Windows will correctly create a hole through all the layers.
- Windows use it to attribute different materials to the different components of the window
So far it won't solve the problem of what happens when two multilayer walls meet, but I think this is already a good step forward. I'm specially happy to have found a simple, unified way to handle more complex wall definitions. The multimaterial system can easily be extended to add more properties to material layers if needed.
Another consequence is that now the "migration" of Arch to multi-solids is more or less complete. Before, the paradigm was that each arch object = one solid. Now, it is: each arch object = any number of solids.
regis
Re: Arch MultiMaterials
Post by regis »
Amazing. This looks like revit.
pablogil
Post by pablogil »
I love it.
It will be perfect when you guess how to handle meeting walls and what layers follow the holes (windows and doors) and ones not.
I'll stay tuned ;)
bitacovir
Post by bitacovir »
Great! Well done :D
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Renato Rebelo
Post by Renato Rebelo »
Amazing
But I can not see the various layers in different colors?
In addition, it now lacks a good hatch system ...
Thank you for the excellent work, ;)
Renato Rebelo
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10993 (Git)
Build type: None
Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291
Python version: 2.7.12
OCC version: 7.1.0
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
Post by yorik »
Renato Rebelo wrote:But I can not see the various layers in different colors?
It should be... maybe there is a recompute needed somewhere?
Renato Rebelo
Already made it work, but it only starts working after doing any operation that involves editing the color on the wall and doing a recompute, after that it works normally ...
Post by yorik »
Okay found the problem, it's fixed in git commit aa65230d4
I also added a combo box in the wall creation task panel,so you can now pick a multimaterial when creating a wall. The multimaterial you select there is remebered throughout the session, so next time you use the wall command, it will have the previous multimaterial selected already.
pablogil
Post by pablogil »
I have tested it and it works like a charm!
paullee
Post by paullee »
This is a simple but clever solution! I am exploring how to productively use this feature!
EDIT:
Just minor comments.
1. I find it does not work on closed sketch / Dwire Face - e.g. a rectangular solid column, circular column, wall in trapezoid shape do not work currently....
2. The Multi-material needs to depend on ArchMaterial or it will not work, though hinted in wiki "...Name and Material fields are mandatory....", but it still create an object...
I create a Multi-Material w/o first creating corresponding ArchMaterial, which does not work...double-clicking it return nothing (as it should when I later found when the Multi-material is created properly.) When the Multi-material is created w/o selecting the materials in the dialog box (when it should have been), OK return silently w/o warning, and created an object that could not be further edited or rectified.
BTW, what would you use this Multi-material for as an example?
OS: Linux
Version: 0.17.11009 (Git)
Build type: Unknown
Hash: 77386684fb76c0d91ea05cc6a0e005d5d8441d21
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
