Posts: 12849 Joined: Sun Sep 08, 2013 8:07 pm
Post
by bernd » Tue Mar 05, 2019 6:25 pm
found it ...
2DPlaneStress.out
Patch test of PlaneStress2d elements -> pure compression
LinearStatic nsteps 1 nmodules 1
vtkxml tstep_all domain_all primvars 1 1 vars 5 1 2 4 5 27 stype 2
domain 2dPlaneStress
OutputManager tstep_all dofman_all element_all
ndofman 8 nelem 5 ncrosssect 1 nmat 1 nbc 3 nic 0 nltf 1 nset 3
node 1 coords 3 0.0 0.0 0.0
node 2 coords 3 0.0 4.0 0.0
node 3 coords 3 2.0 2.0 0.0
node 4 coords 3 3.0 1.0 0.0
node 5 coords 3 8.0 0.8 0.0
node 6 coords 3 7.0 3.0 0.0
node 7 coords 3 9.0 0.0 0.0
node 8 coords 3 9.0 4.0 0.0
PlaneStress2d 1 nodes 4 1 4 3 2 NIP 1
PlaneStress2d 2 nodes 4 1 7 5 4 NIP 1
PlaneStress2d 3 nodes 4 4 5 6 3 NIP 1
PlaneStress2d 4 nodes 4 3 6 8 2 NIP 1
PlaneStress2d 5 nodes 4 5 7 8 6 NIP 1
Set 1 elementranges {(1 5)}
Set 2 nodes 2 1 2
Set 3 nodes 2 7 8
SimpleCS 1 thick 1.0 width 1.0 material 1 set 1
IsoLE 1 d 0. E 15.0 n 0.25 talpha 1.0
BoundaryCondition 1 loadTimeFunction 1 dofs 2 1 2 values 1 0.0 set 2
BoundaryCondition 2 loadTimeFunction 1 dofs 1 2 values 1 0.0 set 3
NodalLoad 3 loadTimeFunction 1 dofs 2 1 2 components 2 2.5 0.0 set 3
ConstantFunction 1 f(t) 1.0
in the LinearStatic the count of export modules needs to be specified by nmodules 1
I would like to run the Calculix Cantilever with oofem. ATM I stick with boudary conditions and load. I do not really understand how this works. Some reading is needed. Have you made the cantilever for oofem? Would save me a lot of time ...
HarryvL
Posts: 1285 Joined: Sat Jan 06, 2018 7:38 pm
Post
by HarryvL » Tue Mar 05, 2019 7:01 pm
Sorry, no I only ran one test case:
to be renamed to concrete_3point.in
Post
by bernd » Tue Mar 05, 2019 7:44 pm
great, it helps anyway thanks ... input file runs smooth with oofem and results opens fine in FreeCAD ...
HarryvL
Post
by HarryvL » Wed Mar 06, 2019 4:59 am
Looks promising.
Post
by bernd » Mon Mar 11, 2019 5:07 pm
HarryvL
Post
by HarryvL » Mon Mar 11, 2019 8:29 pm
Posts: 13434 Joined: Thu Jan 05, 2017 9:03 pm
Post
by Kunda1 » Mon Mar 11, 2019 10:43 pm
Niiice!
Post
by bernd » Tue Mar 12, 2019 10:16 pm
@Harry:
I changed a lot! Since this is something like a documentation how to add a new solver to FreeCAD FEM, I tried to make some readable commit history. Thus your origin commits changed a lot. I tried to keep as much as possible as the origin. Since this might get into master one day ... Would you have a look and give some feedback if the splitting between your commits and my commits is ok for you?
cheers bernd
https://github.com/berndhahnebach/FreeC ... s/femoofem
HarryvL
Post
by HarryvL » Wed Mar 13, 2019 12:03 am
Bernd, I didn't do any work on this since October or so. I didn't get far with this and moved on to writing my own solver. So, I will certainly have a look to learn from your work, but I am not worried if this invalidates or overrides my original efforts. Harry
