OOFem
Re: OOFem
Hi guys, I am one of OOFEM developers and the integration of OOFEM into FreeCAD is really great. If you need any help with OOFEM input file structure or anything else I would be happy to help.
Re: OOFem
Hi and welcome to FreeCAD FEM
http://www.oofem.org/forum/viewtopic.php?id=1804
FYI: Just the basics work, but it works! Means export of planestress elements (I used PlaneStress2D example from manual to set up the input file writer) and tet10 elements as well as constraint fixed and constraint displacement and costraint force (on vertieces only). Neither multiple materials nor nonlinear materials etc.
Eventually this was the most challanging part for someone does not knowing FreeCAD. Extending the oofem writer as it is just ATM is not difficault for someone knowing Python.
What you could do is: "Give it a try!!!" See https://github.com/berndhahnebach/FreeC ... s/femoofem Until it is not merged into FreeCAD master I regulary rebase this branch on FreeCAD master.
- compile the branch
- start FreeCAD
- set the path to oofem binary in preferences
- run the attached code and view results ...
EDIT: from 26. March 2019 it should be:
BTW: The oofem integration is more than just another solver. ATM it is the documentation on "How to integrate a new solver in FreeCAD FEM"
cheers bernd
you helped alreadynitramkaroh wrote: ↑Thu Mar 21, 2019 10:06 amIf you need any help with OOFEM input file structure or anything else I would be happy to help.
thanks for the flowersnitramkaroh wrote: ↑Thu Mar 21, 2019 10:06 amHi guys, I am one of OOFEM developers and the integration of OOFEM into FreeCAD is really great.
- start FreeCAD
from femexamples.manager import *
doc = run_ccx_cantilevernodeload(None, 'oofem')
doc = run_ccx_cantileverprescribeddisplacement(None, 'oofem')
doc = run_oofem_planestress2d()
doc = run_ccx_cantilevernodeload('oofem')
doc = run_ccx_cantileverprescribeddisplacement('oofem')
cheers bernd
Re: OOFem
Thus I rebase fixes and changes to the approprate commits. Means as long as the branch is not in FreeCAD master the git history could (will) change.
Re: OOFem
Beside what @bernd mentions, perhaps it would be beneficial to get OOFem out in to the package ecosystem. Currently nothing returns when one searches OOFem on Repology.orgnitramkaroh wrote: ↑Thu Mar 21, 2019 10:06 amHi guys, I am one of OOFEM developers and the integration of OOFEM into FreeCAD is really great. If you need any help with OOFEM input file structure or anything else I would be happy to help.
Re: OOFem
rebased my oofem branch on latest FreeCAD master and solved all conflicts. Furthermore the history was rewritten. All oofem commits should be according FEM code convention.
Re: OOFem
rebased my oofem branch to latest FreeCAD dev, solved all conflicts and make the unit tests run again.
- ebrahim raeyat
Re: OOFem
Thanks. I must study rebasing with github and then i continue this waybernd wrote: ↑Wed Feb 19, 2020 2:24 pmrebased my oofem branch to latest FreeCAD dev, solved all conflicts and make the unit tests run again.
Re: OOFem
I am trying to compile FreeCAD with oofem capabilities.
However, I got several errors during the compilation.
1. I had to add
into ../../src/Mod/Part/App/FeatureFillet.cpp
2. I got
To move further, I solved this by commenting the appropriate lines.
3. I got stuck with the last one
Could you please advise me, how to solve these issues?
Thanks,
Martin
1. I had to add
#include <Precision.hxx>
2. I got
error: ‘TColgp_Array1OfPnt::TColgp_Array1OfPnt(const TColgp_Array1OfPnt&)’ is private within this context
auto nodes = facets->Nodes();
error: ‘Poly_Array1OfTriangle::Poly_Array1OfTriangle(const Poly_Array1OfTriangle&)’ is private within this context
auto triangles = facets->Triangles();
/bin/sh: 1: PYSIDE2RCCBINARY-NOTFOUND: not found
src/Mod/Material/CMakeFiles/Material.dir/build.make:89: recipe for target 'src/Mod/Material/Material_rc.py' failed
Thanks,
Martin
Re: OOFem
I think you can better ask your question here: https://forum.freecadweb.org/viewforum.php?f=4
Re: OOFem
Your compilation problems do not have to do something wit oofem implementation in FreeCAD.nitramkaroh wrote: ↑Thu Sep 24, 2020 9:27 amI am trying to compile FreeCAD with oofem capabilities.
Try:
- compile latest FreeCAD master from https://github.com/FreeCAD/FreeCAD/commits/master
- if this works for you use FreeCAD oofem branch from https://github.com/berndhahnebach/FreeC ... s/femoofem
- if the FreeCAD master branch comiles oofem branch will compile too. Threre are only rare real changes in C++ My oofem branch is regularly rebased on latest FreeCAD master.
See all FreeCAD oofem changes ... https://github.com/berndhahnebach/FreeC ... 4ea93efdec
Who is online
Users browsing this forum: No registered users and 2 guests
