[Merged] PR #2577: Docs: Update Prefs > Display > '3D View' tooltips
https://github.com/FreeCAD/FreeCAD/pull/2577
I added a longer explanation about VBO and spruced up some other tooltips.
Please advise what the tooltips for 'Render Cache' and 'Rotate at cursor' should be.
Re: PR #2577: Docs: Update Prefs > Display > '3D View' tooltips
Do this
git grep -i 'Render cache'
So, by checking this file in GitHub, https://github.com/FreeCAD/FreeCAD/comm ... s3DView.ui
we see the person who added that option was realthunder in git commit c744157, with the LinkMerge. So, you may ask him directly.
Similarly for the other string, it seems it was added in git commit a2fa902, by donovaly. I think that's uwestoer in the forum?
super helpful, thanks @vocx
So...looks like @realthunder documented this feature in https://github.com/realthunder/FreeCAD_ ... er-caching
Trying to understand that page is overwhelming. Can tooltips have active URLs in them ?
It seems to be an expert option, so I guess there is not much point in giving a full explanation in the tooltip. Better to try to document it in Preferences Editor page.Kunda1 wrote: ↑Thu Oct 03, 2019 9:57 pm So...looks like @realthunder documented this feature in https://github.com/realthunder/FreeCAD_ ... er-caching
It seems that "Rotate at cursor" is the same as the previously named "Drag at cursor", which already was described by uwe in the wiki.
I guess we can ask @realthunder to summarize it in to a paragraph or so ? (giving 1 line explanation summary for every option)
Yes, it is documented here.
You can use the following description as the tooltip I guess.
Auto (default), let Coin3D decide where to cache.
Distributed, manually turn on cache for all view provider root node.
Centralized, manually turn off cache in all nodes of all view provider, and only cache at the scene graph root node. This offers the fastest rendering speed, but slower response to any scene changes.
Thanks! I've added the tooltip. Do you mind reviewing it ?realthunder wrote: ↑Thu Oct 03, 2019 11:00 pm You can use the following description as the tooltip I guess.
https://github.com/FreeCAD/FreeCAD/pull/2577/files
Edit: I've also updated the wiki page https://www.freecadweb.org/wiki/Prefere ... or#3D_View
Looks fine for the 'Render Caching' document. But for the VBO part, maybe it is better to change 'video device' to 'graphics card'? Something likeKunda1 wrote: ↑Fri Oct 04, 2019 12:38 amThanks! I've added the tooltip. Do you mind reviewing it ?realthunder wrote: ↑Thu Oct 03, 2019 11:00 pm You can use the following description as the tooltip I guess.
A VBO is an OpenGL feature that provides methods for uploading
vertex data (position, normal vector, color, etc.) to the graphics card.
VBOs offer substantial performance gains because the data resides
in the graphics memory rather than the system memory and so it
can be rendered directly by GPU.
Thanks for reviewing. I will make the revision.realthunder wrote: ↑Fri Oct 04, 2019 1:01 am Looks fine for the 'Render Caching' document. But for the VBO part, maybe it is better to change 'video device' to 'graphics card'? Something like
Edit: PR updated
- adrianinsaval
Speaking of tooltips and documentation, can you guys explain what this option does?
