FEM - Dynamic Loads?
HarryvL
Re: FEM - Dynamic Loads?
Post by HarryvL »
JensElmo wrote: Mon May 28, 2018 10:15 am
Jee-Bee wrote: Mon May 28, 2018 8:52 am Can you add you're inp file? with out it we can't see what you changed...
Oh, yes of course, the attachment wonøt let me attach an inp file, so i zipped it
It works after adding:
1) A frequency step as advised above
2) A density card, which you forgot:
*MATERIAL, NAME=SolidMaterial
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
HarryvL
Post by HarryvL »
FEMMeshNetgen.inp.zip
(61.44 KiB) Downloaded 80 times
JensElmo
Post by JensElmo »
Thanks so much, now it seems to work.
A quick question, what program are you using to make that picture with results?
Post by bernd »
JensElmo wrote: Mon May 28, 2018 11:37 am A quick question, what program are you using to make that picture with results?
CalculiX cgx the post processor of CalculiX ccx
HarryvL
Post by HarryvL »
bernd wrote: Mon May 28, 2018 12:18 pm
Yup. Better use FreeCAD though :D
stephio_maf
Post by stephio_maf »
Hello,
Could you help me to understand how to set a dynamic load for a thermomechanical analysis?
I I have 4 steps, I apply some loads from the beginning and I apply the rest of the loads on the 3rd step.
is it possible to set this in Freecad FEM UI?
Kazu
mac_the_bike
Post by mac_the_bike »
HarryvL wrote: Mon May 28, 2018 12:29 pm
HarryvL, bernd and JensElmo --
Steady State Dynamics:
Sorry this is a bit late (by 1 year!) but have checked that you are plotting the displacement that you think you are.
The displacements from an SSD analysis are complex, i.e. they have real and imaginary parts, and plotting just the real or imag part doesn't mean anything.
The displacements that should be plotted are the amplitudes, i.e. the sqrt(real**2 + imag**2), i.e. the magnitude of the displacement.
mac
HarryvL
Post by HarryvL »
Indeed. This came up in several posts.
