How to run Addon Manager in Headless mode?
Re: How to run Addon Manager in Headless mode?
Post by Kunda1 »
Made some headway by adding command line parsing
But i hit a wall
list index out of range
Also I still haven't successfully compiled FC-dev... so still using the appimage for testing.
Therefore I haven't 'modularized' the script at all.
Testers needed:
wget https://gist.githubusercontent.com/luzpaz/f3bfaaef8aaec9c66b96e0941f6ed7a5/raw/3e7033c4dfe11771ee76911648be875e1298eada/AddonMangerHeadless.py
freecadcmd -c AddonManagerHeadless.py
Post by Kunda1 »
Kunda1 wrote: Sat Oct 26, 2019 1:53 pm
Buh, this sucks. I know it has something to do with the sys.argv[] stuff at the end of the script... but I can't figure it out
kkremitzki
Post by kkremitzki »
Kunda1 wrote: Sat Oct 26, 2019 4:40 pm
Can you post the full error message? I don't get it when trying your reproduction steps above.
sgrogan
Post by sgrogan »
line #39, readline isn't a module, removing this.
line #322
>>> print("{0}\n".format(sys.argv))
['C:\\Users\\Chris\\GitHub\\FreeCAD-build2\\bin\\FreeCAD.exe']
then the error on line 323
  File "C:/Users/Chris/AppData/Roaming/FreeCAD/Macro/headless.FCMacro", line 323, in <module>
    if sys.argv[3] == "list":
<class 'SyntaxError'>: ('invalid syntax', ('C:/Users/Chris/AppData/Roaming/FreeCAD/Macro/headless.FCMacro', 323, 13, '    print sys.argv[3]\n'))
"fight the good fight"
Post by Kunda1 »
sgrogan wrote: Sat Oct 26, 2019 5:14 pm line #39, readline isn't a module, removing this.
line #322
Thanks, that fixed it.
Update script.
https://gist.github.com/luzpaz/f3bfaaef ... 7739c95870
Post by Kunda1 »
Added import logging to enable/disable debugging of the script
https://gist.github.com/luzpaz/f3bfaaef ... cc01b504d8
Post by Kunda1 »
https://gist.github.com/luzpaz/f3bfaaef ... ss-py-L180
            gitrepo = git.Git(clonedir)
clonedir == ~/.FreeCAD/Mod/<addon_name>
so essentially it's
            gitrepo = git.Git(~/.FreeCAD/Mod/<addon_name>)
I don't understand what git.Git is doing here. Can't find mention of it in the GitPython API for git.Git
Post by Kunda1 »
Post by Kunda1 »
Figured out the list index out of range issue. It was the way i was using sys.argv to check items in the list. Fixed it. But then something else broke. I'm still confused as to what the function of git.Git() does
https://forum.freecadweb.org/posting.ph ... 9#pr343385
Post by Kunda1 »
