Thanks all for the great support,
I checked out the latest master and compiled it.
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.18779 (Git)
Build type: Unknown
Hash: cbe161b4e464a49e8d16fd9a1bf3b5e8d72de24d
Python version: 3.6.8
Qt version: 5.9.5
Closing FreeCAD I get the questions for saving all dependent files, each file gave an error message:
<Gui> Document.cpp(996): Document::getDependentDocuments: The graph must be a DAG.
This was already in earlier versions the case.
I hope the saved file is now without any absolute paths. But as stated by Zolko, there is at the moment no way to mill directly from assembly 4 parts.
If someone has another idea I'm glad to hear about.
Regards Sören
Using Parts in Path from an Assembly 4
Re: Using Parts in Path from an Assembly 4
- flinny_box.zip
- Just saved ine latest FreeCad
- (180.52 KiB) Downloaded 25 times
It's not possible to mill from an App::Part, and since Assembly4 uses App::Part as building blocks you can't directly mill. What you can do is copy the body/solid of your part into a new document, and do the Path things there:
BUT ... why do you have 2 files for the 2 large sides, and 2 for the 2 small sides: are they not identical ? Because if they are identical, you are supposed to have 1 file for the large sides, and link that file twice into the assembly. That's the whole point of App::Link.
I tried to create a simple copy of the whole Part. It sort of worked, i.e. it looks ok, but Check geometry shows lots of errors and Path doesn't recognize any of the solids either.
Thank your for already trying this, I didn't find the time yesterday, is it possible that the errors arise from the dependency to the worksheet with the measurements ?
