Small single-family house made of foam concrete.
rmavrichev
Post by rmavrichev »
My project of the small single-family house made of foam concrete.
https://github.com/rmavrichev/freecad-p ... _8500x9500
small_one_family_house_built_from foam_concrete.png (739.79 KiB) Viewed 7506 times
UPD: latest version:
project file:
https://github.com/rmavrichev/freecad-p ... 5_20.FCStd
thschrader
Re: Small single-family house made of foam concrete.
Post by thschrader »
Downloaded your file, excellent work!
rmavrichev
thschrader wrote: Wed Dec 04, 2019 1:17 pm Downloaded your file, excellent work!
Thanks! These are my first steps in freecad. But I had some experience with autocad and varicad.
bitacovir
Post by bitacovir »
Good work.
If you built it, show some pictures.
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
carlopav
Post by carlopav »
Very nice and tidy model.
How did you model the windows?
rmavrichev
The model is not completed yet. But arch workbench have a good tool for creating windows.
I used this tool in my other project of the small bathhouse built of profiled logs.
https://github.com/rmavrichev/freecad-p ... m_wood.png
Willem
Post by Willem »
I like this project, but 1 comment. I am afraid that when I am on top of the stairs I hit my head to the roof. My suggestion is to rotate the top of the stair 90 degrees to the middle of the house
rmavrichev
I made some changes to the improved version of the interior layout.
triplus
Post by triplus »
Nice work!
Zolko
Post by Zolko »
rmavrichev wrote: Mon Dec 09, 2019 5:21 pm I made some changes to the improved version of the interior layout.
In the bathroom, you have water coming from all 4 walls, and sewers going down on 3 walls, that's going to make a lot of plumbing. Especially the toilets are going to be a PITA. Can't you regroup the water supply and sewer needs into a more concentrated region (ideally 1 wall) ? And close to the needs with the kitchen ? Much less hassle to actually build.
