shell to shell contact
Re: shell to shell contact
Post by bernd »
how did you crrate them? I did extrude a circle. Standard value for splitted file writing is False, means no line is one input file, AFAIK.
UR_
Post by UR_ »
bernd wrote: Wed Jan 15, 2020 8:05 pm how did you crrate them?
Here is a fixed version.
Should be meshable, because tubes are compounded and point of force application is boolean fragmented.
Tube's faces are reversed too.
Please have a try.
contact_shell_shell.py
(7.49 KiB) Downloaded 17 times
thschrader
Post by thschrader »
bernd wrote: Wed Jan 15, 2020 8:05 pm how did you crrate them? I did extrude a circle. ...
part-wb: create cylinder
arch-wb: select one or more surfaces on cylinder, press facebinder button
mesh it.
facebinder.FCStd
(247.17 KiB) Downloaded 14 times
Post by bernd »
UR_ wrote: Thu Jan 16, 2020 9:12 am Here is a fixed version.
https://github.com/berndhahnebach/FreeC ... ellcontact LGTM
Post by bernd »
bernd wrote: Wed Jan 15, 2020 8:05 pm ... Standard value for splitted file writing is False, means no line is one input file, AFAIK.
with this git commit 2f0d34e it is explicit set for all examples
Post by bernd »
thschrader wrote: Thu Jan 16, 2020 11:46 am
mesh it.
this is what I would do if I would create them with the GUI as you did. The extrusion way was just faster to code in Python.
Post by bernd »
merged it
thschrader
Just done with
OS: Windows 10 (10.0)
Version: 0.19.19311 (Git)
Hash: 120b69c74f7dac8c4fa6dbc0a7e10674bde9216c
Python version: 3.6.8
Qt version: 5.12.1
Using 1.st order shell elements, gmsh/ccx from Freecad/bin-folder. Bernd: thumbs up! :)
Post by bernd »
very cool Thomas :)
BTW: fixed a nasty typo ... git commit 1550d26
Post by Kunda1 »
Don't forget to mention in the 0.19 Release Notes thread about this new feature in FEM
