Issues doing sweep on helix
Hello everyone!
I'm completely new to FreeCAD (I normally use some private CAD software everyone knows) and I'm having a lot of trouble trying to make a sweep. Briefly explained, I created an sketch containing a triangle on the XZ plane. Then I create a helix and moved the beginning of the helix to the point that should follow the helix. Couple of days ago I was able to sort this using a datum point from the helix as a constraint for the triangle sketch and that kind of worked, but now I'm trying to do it on a more straight forward way and it is definitely not working xD. Here I'm going to attach the screenshots and the project file. Also, I'm open to any recommendations about how to use the part/body workflow.
- torque.FCStd
- project file
- (73.1 KiB) Downloaded 14 times
- this is the one I got to work
- expected.jpeg (51.21 KiB) Viewed 923 times
- this is my current result
- reult.jpeg (60.4 KiB) Viewed 923 times
Re: Issues doing sweep on helix
There are several things wrong:
- You have to set Frenet=true in the sweep. This yields already a thread, but it is far too large.
- For the Part-Sweep you used a PartDesign-triangle from inside a body. That leads to a warning in report view. You should have used a sketch created from Sketcher workbench instead.
Repair:
- select the sketch of the triangle
- select MapMode in the DataTab
- click on the occurring ...-Button
- select "deactivated" and confirm
- move the triangle with the mouse out of body and enclosing part, i.e. move it over the filename
Now you see where it really lives and you can move your helix accordingly.
Repair:
Great, it worked perfectly. The sweep solid, should I add it again to the body/part i was working on or just keep it there until I use it for dome boolean operations? I'm a little concerned about the workflow. I thought everything should be inside a body.
Never mind. Now I can't do a boolean operation (union) between a pad and the sweep. I'm sorry but I will revert to another software. Loved the sketch system on freecad, but nothing works here and you don't even have error messages. You users are very skilled and patient
Just for the record: It is indeed recommended to stay in one workbench if possible. So you should have used the PartDesign sweep, and not the Part sweep. However, the Helix has to be made in Part workbench and then must be imported with a ShapeBinder (or as the first BaseFeature in the body).
How is it suppose I can be aware of all of this without any initial information? Is it supposed to read all the software documentation before creating a simple sweep?chrisb wrote: ↑Wed Jan 15, 2020 9:46 pm Just for the record: It is indeed recommended to stay in one workbench if possible. So you should have used the PartDesign sweep, and not the Part sweep. However, the Helix has to be made in Part workbench and then must be imported with a ShapeBinder (or as the first BaseFeature in the body).
No, but it helps.anxietyscroll wrote: ↑Thu Jan 16, 2020 9:47 pmIs it supposed to read all the software documentation before creating a simple sweep?
So, I was following this tutorial because I can't just give up on this stuff (https://www.youtube.com/watch?v=vaAkivnTq10) and found that the diameter of the helix can not be the same as the diameter of the cylinder (for sure, nothing better than making all in approximations). And that's how you can get a simple sweep to work on Freecad. (totally migrating to another software).
- Useful information
- Screenshot from 2020-01-16 18-40-53.png (17.74 KiB) Viewed 816 times
- After knowing the bug
- Screenshot from 2020-01-16 18-41-16.png (39.19 KiB) Viewed 816 times
- Before knowing the bug
- Screenshot from 2020-01-16 18-41-47.png (37.81 KiB) Viewed 816 times
Another customer happily served!
So, can't give up, but doesn't have the patience...to not give up.
